Video warning when card is full at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
AJA Io and Ki Pro
...plus others from the AJA product line.
Old June 2nd, 2011, 10:46 AM   #1
When on the shoulder with my F3 I can’t see the status of my Ki Pro mini causing a bit of stress during takes wondering where my cards are at media wise. I will soon be in the market for an evf is there anything in the works where when viewing either HDMI or SDI out from the Ki Pro that the unit would signal in some way the card is full on the viewfinder? Even just turning off the video coming out of the Ki Pro would let the cameraperson know it was time to change cards.
Steve Cocklin is offline   Reply With Quote
Old June 2nd, 2011, 12:08 PM   #2
AJA
Re: Video warning when card is full
Steve C. - All of the buttons on the front of the Ki Pro Mini flash at 15% remaining capacity with a "WARNING Media Low" prompt also appearing on the Ki Pro Mini UI screen. We typically recommend users swap out media at this point to avoid missing an upcoming take. At 10%, the "WARNING Media Full" appears and again all of the backlit buttons flash several times.
I appreciate that if it's on your shoulder, it's not as easy to see the flashing buttons, so it's probably wise to just check the remaining capacity from time to time. As much as it would be great to communicate information back to a camera's eyepiece, that's really not possible as the camera's information reporting is a closed system. Blacking out the output really wouldn't be helpful if you wanted to continue using the EE output of the Ki Pro Mini and it could make for complications if you wanted to play back a full CF card on the unit, etc.
Hope this makes sense,
Jon Thorn
Product Manager
AJA Video Systems, Inc.
Jon Thorn is offline   Reply With Quote
Old June 12th, 2011, 07:09 AM   #3
I have the following suggestion as I had both memory card full and low batterry warnings were the unit shuts down itself without noticing. Pretty scaring this happening when it sits back on your shoulder turning out there is no recording.
I now use the headphone out to at least hear the unit is working.
Doing this got me to this suggestion.
Can you please add audio beeps when it starts/stops recording like one/two short beeps?
Then when there is a warning use longer beeps, or when it's going to shut down or stop recording alarming beeps.
This would make it so much better to at least know the unit on the back is doing it's thing and is recording.
Marc Colemont - Belgium - http://www.mc-productions.be
JVC GY-HM850's, HM890, HM600
Marc Colemont is offline   Reply With Quote
Old June 12th, 2011, 04:28 PM   #4
AJA
Marc C. - We can take your suggestion under consideration, but I cannot say whether or not it could or would be implemented.
Thank you for your feedback,
Jon Thorn
Product Manager
Old June 14th, 2011, 05:32 AM   #5
Thanks Jon and the AJA-team to take it in consideration.
I do think it would give great value to the product.
Marc Colemont
Old June 30th, 2011, 05:45 AM   #6
I second that. Please give us the option of an audible warning!
Jim Tittle is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
