Notice Regarding Ki Pro Mini Qualified CF Cards at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
AJA Io and Ki Pro
...plus others from the AJA product line.
Old March 2nd, 2011, 04:38 PM   #1
AJA
An issue has come to our attention regarding the use of Lexar 32GB Professional 600x Compact Flash cards as originally qualified for use with the Ki Pro Mini. If the Lexar Compact Flash cards are inserted in the Ki Pro Mini prior to powering up the unit, the Lexar Compact Flash cards will falsely report recording; in actuality data will not be written to the Compact Flash card as expected. While this issue does not occur if the Lexar Compact Flash card is inserted after the Ki Pro Mini is powered up, we can no longer recommend the use of these cards at this time. We are actively working to determine the cause of this issue, but for now, the Lexar 32GB Professional 600x Compact Flash card has been removed from our list of qualified Compact Flash cards for use with Ki Pro Mini.
Please note that the issue described above for the Lexar Compact Flash card does not affect the other cards qualified for use with the Ki Pro Mini. Additionally, we will be adding new choices to the qualified list of Compact Flash cards for use with Ki Pro Mini in the near future.
We apologize for any inconvenience the recommendation of the Lexar 32GB Professional 600x Compact Flash card may have caused.
The amended Qualified Compact Flash Card document can be found here:
http://www.aja.com/pdf/KiProMini_qualifiedCF_cards.pdf
Jon Thorn is offline   Reply With Quote
Old March 5th, 2011, 08:14 PM   #2
Re: Notice Regarding Ki Pro Mini Qualified CF Cards
You're welcome :o)
Don Greening is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
