Timecode issue at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
AJA Io and Ki Pro
...plus others from the AJA product line.
Old March 1st, 2011, 08:08 AM   #1
Timecode issue
Hey,
I am having a time code issue...
the timecode wont reset after we put in a new hard drive/reel? it start of right after the previews recording...
could not find anything in the manual anybody has a tip?
Apple Pro
Shaggy Franks is offline   Reply With Quote
Old March 1st, 2011, 09:50 AM   #2
AJA
Re: Timecode issue
Shaggy F. - The timecode value on the Ki Pro does not reset when you insert a new Storage Module. This is by design. If you want to change the value, simply enter the CONFIG menu and adjust the TC Value parameter to one of the hour values presented; 01:00:00:00, 02:00:00:00, etc.
If you wish to reset to 01:00:00:00 and that's the value you have been using, you can do this one of two ways. First, use the ADJUST up arrow to go to 02:00:00:00 then ADJUST down to go back to 01:00:00:00. Second, you can also reset any individual parameter back to it's default by holding down the ADJUST up and down buttons at the same time.
Hope this is helpful,
Jon Thorn
Product Manager
AJA Video Systems, Inc.
Jon Thorn is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > AJA Io and Ki Pro
