Takes ages to transcode in encore?
I have a 2min fil im putting on dvd, ive made the menues and everything and then goto build and the bar counts up for the transcoding, then it reaches the end, goes back 1/4 and counts again. It does this over and over again.
Is something wrong? Also, it doesnt seem that Premiere and encore are linked together as I cant export in premiere to Encore. I have PPro CS3 and encore 2 It also does it when I import an .mv2 mpeg 2 file saved from premiere Last edited by Richard Grebby; July 24th, 2007 at 11:13 AM. Reason: update |
#2 | |
The fact that it takes so long to render could be that you used a 2 pass vbr which can take long if you don't have a dual- or quadcore pc. |
