OnLocation Question at DVinfo.net
Adobe Creative Suite
Old July 9th, 2007, 12:02 PM   #1
Is OnLocation just DVRack 2?
I have DVRack2 and I love it, so I was looking forward to OnLocation, figuring it would be a next generation product. Howeer, it looks like DVRack 2. Are there any new feature that would warrant an upgrade?
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old July 11th, 2007, 08:35 AM   #2
OnLocation Question
Anyone know what improvements have been made since the last DVRack release?
Paul Cascio
Old July 12th, 2007, 02:31 PM   #3
No, but I think a new version is in the works.
Philip Fass is offline   Reply With Quote
Old July 12th, 2007, 04:38 PM   #4
Phillip, what do you mean? If they just released Onlocation, how long before a new version?
I DLed the demo version and see nothing changed from DVRack.
Paul Cascio
Old July 12th, 2007, 04:56 PM   #5
Probably two years. That is the regular upgrade sequence for Adobe. If you look at the speed with which they updated CS2 to CS3, or better said 2.00 to 2.01, just a point release, not a version upgrade, and kept bugs in, in some cases even enlarged problems and removed functionality, it makes you wonder what they are trying to prove, while at the same time charging extravagant prices...
Old July 13th, 2007, 04:03 AM   #6
The SM team (now at Adobe) takes suggestions for new features, and implies that other features are in the works. It won't be soon, and it may not be a stable upgrade, but there will probably be some interesting bells & whistles eventually. Meanwhile, save your money.
Old July 19th, 2007, 06:44 AM   #7
On Location Pulsing Monitor
Just installed OnLocation but the monitor is pulsing. Very regular about ½ second intervals, looks like some sort of interference but I don't think so.
Using the xh-a1 and the lcd on the camera doesn't pulse. Hdvsplit doesn't pulse (no monitor though). Played back a recorded clip in OL and the pulsing was there. The waveform monitor pulses also.
Any ideas? Settings I overlooked?
Thanks.
Brad Tyrrell is offline   Reply With Quote
Old August 29th, 2007, 03:41 PM   #8
A little slow on the reply but I've seen this too... and with an A1 as well. It appears to have something to do with the black level. It's not there when I load the footage into Premiere Pro so I've just been ignoring it. I keep meaning to go over to the support forum and see if there's anything on it but it's been low on my list. I miss Serious Magic support.
-Dan
Dan Wilder is offline   Reply With Quote
Old August 30th, 2007, 07:30 AM   #9
Yeah, not there in Premiere so I don't worry about it anymore. Just wish there were an explanation somewhere so that I wouldn't have worried about it in the first place. Probably something to do with not using too much processor power for the display section when capturing.
Should this be a sub in the Premiere area of the forums now that OnLocation is part of the CS3 package?
Old February 1st, 2008, 11:27 AM   #10
Does DV Rack Version 1.2.1490.0 Support 24Pa?
I have the original DV rack and capture using type II avi. But does this support my Panasonic DVX 100b 24Pa mode?
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline   Reply With Quote
Old February 2nd, 2008, 06:36 PM   #11
Does OnLocation record sound better than HDV tape?
I was wondering if the sound coming from the FW into OL is different, i.e. better than if recorded on tape?
Paul Cascio
Old February 2nd, 2008, 11:18 PM   #12
Nope - same camera preamps, same encoder to DV or HDV signal, what comes down firewire should be identical to what goes on tape, and DVRack design philosophy is to put that signal on hard drive with nothing modified, added, or taken away.
Barring tape damage the FW signal should be identical in every way.
There are a few cameras that do have outputs that bypass encoders for a live signal, eg. the Sony HVR-V1 has an HDMI output that on a live shot is closer to raw, the EX1 has SDI/HD-SDI with embedded audio. But DVRack only works with firewire DV and (with DVRack 2HD) HDV.
Seth Bloombaum is offline   Reply
