audio mixer troubles in pro 1.5 at DVinfo.net
Adobe Creative Suite
Old June 12th, 2007, 10:51 AM   #1
When I'm playing a sequence, and using the audio mixer to "write" say bringing the master down from 0 to -6.... and then after I stop it stays that way.... well further down the sequence I want it back to zero, but I now do I have to play in real time through the rest of the sequence with "write" and the master at 0? or is there a way I can type in or force it back up to 0 and it will stay there?
cheers!
Matt
Matthew Jackson is offline   Reply With Quote
Old June 12th, 2007, 12:03 PM   #2
You have to add keyframes.
Ervin Farkas
www.AtlantaLegalVideo.com
Old June 12th, 2007, 12:51 PM   #3
No, here's the problem... for the clip, I can put keyframes in and control the volume, which is what I should have done all along... but for whatever reason, now my MASTER volume that controls all the tracks wants to suddenly shift down to -6 on it's own and stay there, effecting all keyframes, and other track volumes... so I've really kind of put myself in a pickle...
Is there a way to reset that or override it without just playing the sequence from start to end with it set to "write" and have it set at 0?
