Advantage of slow mo in After Effects VS Premiere? at DVinfo.net
Adobe Creative Suite
Old June 3rd, 2007, 01:37 PM   #1
I use a lot of slow motion in my work. On this website, I've noticed a lot of people talking about creating slow motion clips in After Effects.
What is the advantage of creating a slow motion clip in After Effects, as opposed to right clicking on the clip in Premiere (Pro 1.5) and changing the speed/duration to say 50% or 40%? That's what I've been doing, but if there's a better way I'd love to learn...
thanks!
Matt
Matthew Jackson is offline   Reply With Quote
Old June 3rd, 2007, 03:59 PM   #2
Premiere is notoriously bad with slomo's, whereas the time remapping in AE is far better. If you don't have AE, you could use Twixtor for slomo's as a plug-in for Premiere.
Old June 3rd, 2007, 04:07 PM   #3
no, I have AE 6.5, but I just never knew what the difference was between the two...
so it's really worth taking your clip into AE and then exporting back out? Is there anything more than just simply remapping or stretching the clip? And checking the frame blend box?
Old June 3rd, 2007, 05:10 PM   #4
The frame blend box is checked by default. I would suggest to take a short clip and apply a slomo both in Premiere and in AE and see which looks better to you and then take into consideration the time spent to achieve the slomo. Then decide. From my experience (but I am also using Twixtor) the effort to use AE and the time remapping tool is worth the time and effort, but if you wait a little while CS3 will be out and the new time remapping feature in Premiere should now closely resemble the AE results you can currently achieve.
Old June 5th, 2007, 05:09 PM   #5
Premiere 6.5 actually does slow motions better than premiere pro 2. It uses the interlacing fully and premiere pro just blends everything.
Mikko Lopponen is offline   Reply With Quote
Old June 7th, 2007, 09:13 PM   #6
Premiere Pro CS3 uses much of the After Effects slow motion engine. But it is still better to use Time Remapping in AE as far as I can tell so far.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old June 8th, 2007, 01:18 AM   #7
Images: 1
Not sure what time remapping does but if you take interlaced footage and spread it out to 200% duration AE will deinterlace and put the even/odd fields consecutively next to each other for 50% slow-mo. Premiere just blends, and it's ugly.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old June 9th, 2007, 06:50 AM   #8
thanks guys for the help! Yea, AE definitely makes a difference...
By the way... when using the Time Stretch and clicking the frame blending switch... be sure to click the main frame blending button above the click boxes to turn on frame blending... you have to do both.
thanks!!
Old June 10th, 2007, 06:00 AM   #9
So how do AE and PPro de-interlace 25p footage from the V1? I've never been able to figure this out but I know I'm not happy with PPro's idea of slow motion.
John Hewat
Mammoth Media Productions
John Hewat is offline   Reply
