Exporting HDV 24f m2t footage at DVinfo.net
Adobe Creative Suite
Old May 13th, 2007, 09:23 PM   #1
What's the best exporting options? For either SD DVD or HD video file (AVI, MPEG2, ect.) Everything i keep exporting is all glitchy and jumpy.
-thanks in advance
James Jackson is offline   Reply With Quote
Old May 15th, 2007, 12:05 PM   #2
IMHO, Adobe's Media Encoder is "broken" when it comes to down-rezzing from HDV to SD. It's horrible with down-rez! I use Debugmode's FrameServer (free... Google it) right from the PPro timeline and into a standalone encoder like ProCoder, TMPGEnc Express, or MainConcept's for beautiful down-rezzes.
You could also go intermediates with HuffyUV (free) or Cineform ($$$) and then into the encoder of your choice. OR, import your HDV project into an SD preset and scale down everything.
Let's hope Adobe fixes their encoder on CS3!!
Brian Brown
BrownCow Productions
http://www.brownland.org/blog/
Brian Brown is offline   Reply With Quote
Old May 16th, 2007, 07:08 PM   #3
Brian Brown
Thanks for the reply man!!!
Old May 17th, 2007, 03:06 PM   #4
If your footage is glitchy and jumpy, you're probably using the wrong settings. As Brian stated above, Adobe is responsible for the quality, so exporting directly from Premiere will not be top notch, but the resulting video should not look glitchy or jumpy.
You may need to double check on your field order - while HDV is upper field first, standard definition DVD is lower first.
Ervin Farkas
www.AtlantaLegalVideo.com
Ervin Farkas is offline   Reply
