image grabs at DVinfo.net
Adobe Creative Suite
Old April 27th, 2007, 10:20 AM   #1
image grabs
Good Morning,
I am working on a project and I wanted to grab stills out of the video footage. This is dead easy in elements, but in pro I have not sorted out how to do that.
so, how do I grab stills in pp1.5???
thank you
DATS ALL FOLKS
Dale W. Guthormsen
Old April 27th, 2007, 10:25 AM   #2
Ctrl + Shift + M
I think that will do it, at least in Premiere Pro V2.0.
www.dyweddingmedia.com
Michael Steeves is offline   Reply With Quote
Old April 27th, 2007, 11:17 AM   #3
Select the clip on the timeline (just click on it), the go > File > Export > Still (or it migh be Frame).
Ervin Farkas
www.AtlantaLegalVideo.com
Old April 27th, 2007, 11:01 PM   #4
thank you I will give it a try and report back.
thank you.
DATS ALL FOLKS
Dale W. Guthormsen
Old April 27th, 2007, 11:09 PM   #5
Yeah, Dale. Move the timely marker to the frame you want to grab, then select export, frame, and select the format you want.
Chris J. Barcellos
Old April 27th, 2007, 11:09 PM   #6
thanks
Well,
You were both right!!
thank you both very much for the response!! saved me a lot of time. I had already went through my reference books, never thought to look up frame!!!
DATS ALL FOLKS
Dale W. Guthormsen
Old April 29th, 2007, 01:07 AM   #7
i'm having a problem with this actually..
I have a canon xh-a1 which shoots hdv @ 1440x1080 (1080i) but the aspect ratio is HD anamorphic (1.333).. looks fine in the preview window, exports fine, etc no problem.. but when i do screen grabs they export 4:3. i can manually stretch them with photoshop, paint, etc but its not really ideal as they dont really 'look right' with this method.
any suggestions/alternatives? i tried exporting frame with media player classic when viewing source material and same thing happened.. dont really understand since it worked before fine.
David Warren is offline   Reply With Quote
Old April 29th, 2007, 06:23 AM   #8
Images: 1
Hi David I've had this issue what I did was export the frame click the settings button click on video, then change the frame size to 1920x1080 and change the pixel aspect ratio to square pixels (1.0)
Russ
Russell Pearce is offline   Reply
