Canon HDV and Adobe Premiere - Page 8 at DVinfo.net
Adobe Creative Suite
Old October 16th, 2007, 08:16 AM   #106
I know this used to be an issue with CS2. The solution most of the time was either to export it in HD, import it into a SD timeline, scale the footage, then render. Lots of extra work sadly. I personally encode most of my videos in multiple formats so I normally render an HD file, then use Squeeze to do a batch job in a few different formats which produces nice videos.
Simple Thought Productions - Life @ 30,000 Words per second
Josh Chesarek is offline   Reply With Quote
Old October 16th, 2007, 09:36 AM   #107
I have cs2. I usually export a full-quality file out of premiere (usually an mpeg2 with a bitrate of 50mbps, sometimes uncompressed) and then scale it with virtualdub and encode to a dvd etc.
Mikko Lopponen is offline   Reply With Quote
Old December 8th, 2007, 07:14 PM   #108
Capture onto Adobe Premiere CS3
Hey I just got a chance to use my schools Canon Xh-A1. Now i'm the first person to use it at my school and i need to some help on how to work somethings.
For starters I can't get rid of the grain on the footage. I have the gain at the lowest setting but the grain is still there.
Also when i uploaded the footage on my computer instead of up loading it 24fps it came out 44.96 fps so is there a special pull down i have to do, because when i tried the edit the audio was off sync and it was a big mess.
This is also my first time using HDV
Thato Dadson is offline   Reply With Quote
Old December 9th, 2007, 11:46 AM   #109
Have you installed the Canon F-mode presets for Premiere?
http://www.adobe.com/support/downloa...jsp?ftpID=3408
"Those who dream by day are cognizant of many things which escape those who dream only by night."
-- Edgar Allan Poe
Even Solberg is offline   Reply With Quote
Old December 9th, 2007, 12:16 PM   #110
Did you turn off agc? First thing you learn ;)
Canon XH A1 -> Blackmagic Design Intensity Pro
Manfrotto 701RC2 on 755BK
Rolf Seitz is offline   Reply With Quote
Old December 9th, 2007, 07:58 PM   #111
Thank you for the link so that is installed.
And how do i turn off the agc and what does agc stand for?
Old December 10th, 2007, 10:45 AM   #112
AGC = automatic gain control. It automatically increase gain in the analog video input amplifiers (reading signal the CCD) to provide "normal" image brightness. When shooting in low light conditions this can result in additional gain and corresponding increased apparent grain and video noise.
To avoid AGC, do NOT use the Green Box (easy recording) mode, and turn off the AGC switch. Set the AGC level selection switch to a level you can live with. See page 60 of the manual.
BTW: do not confuse video AGC with audio AGC, aka: Automatic Audio Adjustment described on page 49 in the Canon manual.
dpalomaki@dspalomaki.com
Old February 7th, 2008, 10:18 PM   #113
Canon 30f editing in Premiere CS3
What is the best/correct set up for editing 30F clips in CS3?
There is no Canon 30F preset in the stock installation for CS3.
Adobe offered a 24F and 30F preset for CS2. It allows you to drop 30F clips straight into the timeline and not have to render.
If you copy the same set of CS2 presets into CS3 and drop the same 30F clip into the timeline, CS3 will take time to render the clip. The 24F and 30F does not appear to work efficiently with CS3.
On the other hand, you can drop a Canon 30F clip into a HDV60i timeline and not have to render the clip. A close inspection of the preview shows the "progressive" look intact and there is no interlacing introduced. There appears to be an advantage to this method if you mix an interlaced 60i clip; both 30f and 60i seem to coexists fine.
You can take the same streamcliped .mov 30f clip into FCP 6 with either 30p or 60i setup. FCP seems to be happy either way and reads the file natively.
If you are shooting Canon 30f what presets are you using to edit in CS3?
Hoy Quan is offline   Reply With Quote
Old February 8th, 2008, 01:24 AM   #114
60i and it will be fine.
Kiflom Bahta is offline   Reply With Quote
Old February 8th, 2008, 10:19 AM   #115
That seems to confirm my suspicion that 30F is actually 60i with some behind the scenes processing to make it appear progressive. Appearantly PP CS3 and FCP can read it as 60i and not reintroduce interlacing.
I have tested a mix of 30f and 60i in a CS3 HDV108060i timeline. You can easily see the differences between the clips. When it is ultimately rendered out as progressive (H.264), the 30f clips retain their progressive look and the interlaced clips are deinterlaced to make a continuous progressive movie.
Old February 8th, 2008, 10:37 AM   #116
Are you guys sure that your transtitions are not interlaced???
Todd Clark is offline   Reply With Quote
Old February 8th, 2008, 10:44 AM   #117
DEFINITELY you should be using the 29.97 PROGRESSIVE preset for "HDV". DO NOT use the 60i interlaced... that is wrong. Use the 29.97 progressive (it may be read as 30P, but really it's 29.97 progressive frame).
Deke Ryland is offline   Reply With Quote
Old February 8th, 2008, 12:49 PM   #118
Confirmed - 60i will generate interlaced effects. This is a title with zoom
http://i255.photobucket.com/albums/h...nterlaced1.jpg
So the question remains. Is there anyway to avoid rerendering 30F when dropped into a PP CS3 1080 30p timeline?
Old February 8th, 2008, 01:55 PM   #119
I wouldn't get too concerned about rendering clips to view them (the red line on the timeline). It's something I rarely do, since it doesn't affect the real rendering you have to do to export a sequence. Rendering the timeline (hitting Enter key) just renders transforms, effects and transitions for viewing purposes only. I suspect that progressive footage in PPro requires rendering to view in order to be compatible with viewing devices, Firewire output, etc.
Today's jingle, "Don't sweat it.. edit in 30P." (okay, 29.97, to be exact)
Brian Brown
BrownCow Productions
Brian Brown is offline   Reply With Quote
Old February 10th, 2008, 05:32 PM   #120
1 meg segments of 24f footage????????
Say,
I just tested 60i, 30f, and 24f and noticed that the 60 and 30 came in fine ( a continuous image on the timeline representing 30 seconds of continuous footage) to my timeline but the 24f came in in one meg segments and about 175 of them? WTH? I am using Sony Vegas Pro 8 and currently wondering if I want to shoot in 24f?
Can I still achieve a film like look in post with shooting 60i? Is 30f a good compromise (which seems a bit softer than 60i)?
Tony
Tony Ferguson is offline   Reply
