Possible to put text in letterbox? at DVinfo.net
Adobe Creative Suite
Old April 21st, 2007, 11:22 AM   #1
Hello!
I'm editing HDV footage in Premiere Pro 2. In the program window, the video takes up the entire window (which is a good thing!). But when I export it and select square pixel ratio, letterboxes are added to the top and bottom of the project.
I'm fine with all of this, but I'd like to know how to add text to the letterboxes.
As a side note, I am using Adobe Media Encoder to export the project as a quicktime .mov file using h.264 compression. Also, the frame size of the .mov file is 320x240, while the source video is 1440x1080.
Roland Gatto is offline   Reply With Quote
Old April 21st, 2007, 03:12 PM   #2
The only way I know of to do that would be to create a 4:3 project, import the widescreen project, and scale down the clips to fit sideways, which leaves room at the top and bottom. Use the titler to add text.
But why are you not exporting your widescreen as widescreen?
400X224 works pretty well.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old April 21st, 2007, 06:33 PM   #3
hey steve, thanks for your response. you have been so helpful over the past few weeks!
i'm exporting as 320x240 b/c it's for youtube. would your recommend a different size for youtube? thanks!
Old April 21st, 2007, 07:04 PM   #4
Under 100 MB for youtube. Make if 4:3 aspect ratio. As large and as high quality as you can get it in one of the supported upload formats and still be able to upload (I have Verizion FiOS, so upload speed ain't no big for me...). E.g., 640x480.
Youtube will downconvert--it's larger than 320x240. Also, if you have 16:9 material, then letterbox it before exporting/uploading. I haven't figured out how to get youtube to not squeeze down 16:9 material...
HTH,
Matt
Matt Vanecek is offline   Reply With Quote
Old April 21st, 2007, 07:34 PM   #5
That used to happen to me too, but lately I've been uploading 16:9 anamorphic material and YouTube has been letterboxing it for me. Not sure if they finally got their act together, or I'm just doing something different.
Chris Harris is offline   Reply With Quote
Old April 21st, 2007, 09:17 PM   #6
That means my original answer is the way to go for Roland. Just scale down the footage in a 4:3 project, add the titles and send it to YouTube.
Steven Gotz
