Premiere Pro won't launch in Vista Ultimate 32Bit at DVinfo.net
Adobe Creative Suite
Old February 11th, 2007, 11:07 PM   #1
I just built a new workstation which has Intel Core 2 Extreme, 4GB Ram, one drive set in RAID0 for video editing, scratch disk drive, c:drive 10,00rpm 150GB WD, PNY nVIDIA QUATRO FX1500 with stable drivers for it. Installed Premiere Pro 2.0 , launched it, saw the Premiere loading splash screen for about 15 seconds and that was it... The program never opened up despite the processor light blinking as if any second it will.
My motherboard BIOS is up-to-date for this particular quad processor and everything else seems to work great, even After Effects 7 loaded and works great. One issue with Vista though, it says I have only 3GB of Ram instead of installed 4GB, BIOS says 4GB, but not Windows.
Does anyone have the same issue?
Any comments/suggestions are highly appreciated.
Sincerely,
Renat Zarbailov of Innomind.org
Renat Zarbailov is offline   Reply With Quote
Old February 12th, 2007, 03:48 AM   #2
32-bit version of Vista is, well, 32-bit, which means it has the same memory constraints as Windows XP. Up to 3 GBs.
Bart Walczak is offline   Reply With Quote
Old February 12th, 2007, 04:34 AM   #3
Even in Vista Ultimate 32Bit? Good thing the package came with 64Bit as well.
Sincerely,
Old February 12th, 2007, 05:04 AM   #4
RED Code Chef
The 'problem' exists due to how the 32-bit architecture are setup and hardware
like a graphics card is addressed, more info on some of this:
http://www.microsoft.com/whdc/system...AE/PAEmem.mspx
http://forums.contractoruk.com/showp...3&postcount=40
http://support.microsoft.com/default...b;en-us;555223
http://channel9.msdn.com/ShowPost.aspx?PostID=42545
By far the best thing to do is run a 64-bit OS if you 64-bit drivers exist for that
OS (XP64 or Vista 64-bit). Most 32-bit applications should continue to run if they
run on the 32-bit version.
For your Premiere Pro problem I would navigate to the main executable,
right-click and select "run as administrator". See if that fixes your problem.
Otherwise you can also set properties to run it in XP "emulation" mode. See
if that fixes your problem. Otherwise you'll have to wait for a Premiere update
that adds Vista support.
Rob Lohman, visuar@iname.com
Old February 12th, 2007, 06:46 AM   #5
See this!
Renat,
Save yourself the headache and read this: http://www.dvinfo.net/conf/showthread.php?t=85733.
Ervin Farkas
www.AtlantaLegalVideo.com
Old February 13th, 2007, 03:23 PM   #6
I run PPro 2.0 on Vista 32bit with no problems at all (but I have just 1,5 GB RAM). The same goes for AFX, but it temporarily disables DWM Aero Glass. No biggie.
Jiri Fiala is offline   Reply With Quote
Old February 13th, 2007, 03:32 PM   #7
I resolved the issue by reverting back to the time before Premiere install and installed Quicktime first before going ahead with installing Premiere again. I remembered that the first time I installed it it says that Quicktime isn't on the system so it will install without it, so this might have caused the issue as well as not restarting the system when Premiere asked for it after install.
Thanks everyone who was so kind to help!!!
Sincerely,
