Windows XP 64 bits
Did anyone ever try Windows XP 64 bits with premiere pro 2.0? Is it worth the upgrade? Supposedly regular windows doesn't allow any application to use more than 2GB AND none other version allows 64 bit usage (except vista). I was wondering if anyone tried and what were the results.
I'm curious too. I've got 4 gb installed in anticipation and I hate not being able to use it.
BenWinter.com |
This has been discussed ad infinitum. WinXP Pro supports 4 GB of RAM. PremPro does not support XP64. If you want the hassle, go ahead. Be ready for some serious tweaking in your registry however. Multiple posts about this issue can be found on various forums. Be warned that there is NO performance gain and with Vista recent figures indicate a performance loss of around 25%. If you want to use more memory but suffer a performance loss in render times, go ahead.
Harm,
Windows XP supports up to 3 GBs. I have been running PPro 2.0 on Win 64 for past half a year and it has been the most stable setup I've worked with so far (and I've worked with several). No problems at all. |
#5 |
"The human mind ordinarily operates at only ten percent of its capacity. The rest is overhead for the operating system."
Same with XP. It recognizes up to 4 GB, but applications can only use a maximum of 3 GB. The rest is used by XP. |
#6 |
Does Windows XP automatically use 3GB with premiere pro 2.0 or do I have to set something up?
#7 |
You have to set a switch in the Boot.ini file. Best search the Microsoft Knowledgebase for details.
#8 |
Thanks. I'm going to look into it right now.
#9 |
Ok, I found the switches and I understand they have to be somehow done to the boot.ini file, but I have absolutely no idea how to do it. Can anyone shad some light here?
I found 3 switches that seem useful, but I would like to be sure about which one to use. SWITCH#1 /burnmemory=number This switch specifies the amount of memory, in megabytes, that Windows cannot use. Use this parameter to confirm a performance problem or other problems that are related to RAM depletion. For example, type /burnmemory=128 to reduce the physical memory that is available to Windows by 128 MB. SWITCH#2 /3GB This switch forces x86-based systems to allocate 3 GB of virtual address space to programs and 1 GB to the kernel and to executive components. A program must be designed to take advantage of the additional memory address space. With this switch, user mode programs can access 3 GB of memory instead of the usual 2 GB that Windows allocates to user mode programs. The switch moves the starting point of kernel memory to 3 GB. Some configurations of Microsoft Exchange Server 2003 and Microsoft Windows Server 2003 may require this switch. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 823440 (http://support.microsoft.com/kb/823440/) You must use the /3GB switch when you install Exchange Server 2003 on a Windows Server 2003-based system For more information, click the following article number to view the article in the Microsoft Knowledge Base: 171793 (http://support.microsoft.com/kb/171793/) Information on application use of 4GT RAM tuning SWITCH#3 /maxmem=number This switch specifies the amount of RAM, in bytes, that Windows can use. For example, if you want Windows to use less than 64 MB of memory, use the /maxmem=64 switch. However, the /maxmem switch does not account for memory holes. Therefore, we recommend that you use the /burnmemory switch instead. The /burnmemory switch accounts for memory holes. For example, if you use the /Maxmem=64 switch, and the system requires 64 MB of memory to load, there may not actually be 64 MB availalbe to the system because of a memory hole. In this scenario, Windows would not start. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 108393 (http://support.microsoft.com/kb/108393/) MAXMEM option in Windows NT Boot.ini file |
#10 |
I am using XP x64 and did not have to do anything at all to get Ppro 2.0 to work. I don't know about official benchmarks, but it does run much faster than 32-bit. Previews are faster, rendering is faster, encoding is faster. Everything is faster. It is not fully 64-bit, but it does have some 64-bit optimized code. I don't find it to be particularly stable, though. But then again, I never have found Premiere to be stable.
As far as Vista goes, it is slower overall than XP, so unless the test is between Vista 32 and Vista 64, it doesn't really help us with this question. |
