Is there an "easy" way to transfer a project to another PC? at DVinfo.net
Adobe Creative Suite
Old January 11th, 2007, 06:13 PM   #1
The title says it all. :)
I'm using PPro 1.5
Mike
My short films... The Interview & Calls From The Führerbunker
Mike Horrigan is offline   Reply With Quote
Old January 12th, 2007, 03:53 AM   #2
Copy all the files (including renders and media cache) to removable HDD?
Bart Walczak is offline   Reply With Quote
Old January 12th, 2007, 09:35 AM   #3
So there's no simple "export" function? I've tried but it doesn't seem to export everything...
Old January 12th, 2007, 10:40 AM   #4
Mike, have you tried using the Project Manager feature? Choose it, then the Copy Files function, rather than the Trim Project function. Select your destination (another drive) and make sure your options are all set correctly. You should then have a copy of every file used and imported into your current project.
Section 1 Films
Joshua Clarke is offline   Reply With Quote
Old January 12th, 2007, 10:49 AM   #5
Great! I'll give that a try later and let you know how it works out. That sounds like what I'm looking for.
Mike
Old January 12th, 2007, 12:40 PM   #6
Joshua, that's perfect! The file is huge though...
Mike
Old January 15th, 2007, 09:44 PM   #7
Mike,
No problem. The Project Manager is a great feature in the newer versions of Premiere. Also keep in mind the Trim Project feature for when you want to archive a project.
Section 1 Films
