URGENT HELP! Adobe Audition 2.0 at DVinfo.net
Adobe Creative Suite
Old January 2nd, 2007, 10:35 AM   #1
Am I able to remove music leaving the Voice Over intact from an imported single audio track from Prem Pro 2. I can remove voice from the music which is simple enough, one click but I really need to change the music for a voice over , and I dont have the original Voice over tapes just the master edit tape!!!!!!!!!
I'll try anything....please help!
Will Aldersley is offline   Reply With Quote
Old January 2nd, 2007, 11:58 AM   #2
No. A single track mixed with music and VO cannot be separated. You would have to go to extreme length's to filter one or the other out and the result will be a disappointment.
Old January 2nd, 2007, 04:22 PM   #3
It's so infuriating...I'm usually so good with tapes. Nevermind, I'll just have to use the accepella function to soften the backbeat...thanks
Old January 2nd, 2007, 09:04 PM   #4
There is a FAQ over on the Adobe Forums with some information regarding removing vocals from music and vice versa: FAQ: Removing vocals or removing instruments
Don't expect miracles, by any means. If at all possible the best thing would be to re-record the narration, but if that is impossible for some reason, hopefully the FAQ will assist to some extent.
Christopher Lefchik is offline   Reply
