PAL to NTSC conversion... at DVinfo.net
Adobe Creative Suite
Old September 15th, 2006, 05:03 PM   #1
Howdy! I have a request to post some video clips to an ftp site for some folks in China. Can I use Premiere 2.0 to convert NTSC footage to PAL?
Cal Johnson is offline   Reply With Quote
Old September 17th, 2006, 06:53 AM   #2
I have done this from PAL to NTSC within Premiere Pro 2, so I believe it is possible the other way also.
But notice that the image quality will degrade.
Import your NTSC footage into a PAL project, and render to the format you want. Then the rendered file should be PAL.
Old September 17th, 2006, 10:05 AM   #3
Trond, thank you for reply!
Old June 3rd, 2007, 08:26 AM   #4
Sorry to bump such an old thread but im the process of converting some NTSC footage into pal.
so all i have to do is create a new ntsc project (im using PP2 btw) bring in the footage and render it to 25fps.
are there any issues that i could arise from this?
Liam
www.basicproduction.co.uk
Liam Carlin is offline   Reply With Quote
Old June 3rd, 2007, 08:33 AM   #5
When converting from NTSC to PAL:
You must create a PAL project, and import your NTSC video.
Then you can just "export movie" to create a PAL version of your video.
(or use the media encoder just as you would do with a regular NTSC project)
Like I said in the previous post, your final video will lose some picture quality.
You might want to check out DVfilm's Atlantis software.
www.dvfilm.com/atlantis
This software reportedly gives better quality when converting between PAL and NTSC. (several people have mentioned Atlantis in other threads)
Old June 3rd, 2007, 09:03 AM   #6
Thanks Trond! i have a lot of NTSC footage from Japan (im uk based) so its great i can convert it and it is so simply :)
Thanks Again and thanks for the link :)
Liam
