Problem with video quality output in Premiere 2.0 - Page 2 at DVinfo.net
Adobe Creative Suite
Old August 21st, 2006, 06:55 AM   #16
This topic is not about HD and as I am not working HD yet, I have not looked into it... but a Google search brings up several of them.
For SD, reading this and other websites, Cinema Craft comes up as the winner (and an "ouch" on the pricetag, $2000), I personally tested Sorenson Squeeze and was pleased with the results (also excellent for encoding for the web - WinMedia, QT, Real, Flash).
Ervin Farkas
www.AtlantaLegalVideo.com
Old August 21st, 2006, 09:52 AM   #17
Originally Posted by Ervin Farkas
The mpeg2 encoder included in Premiere and Encore is not the best though, so if you really need higher quality, you should look into using a better encoding software.
That depends. Lars Siden did a test of several MPEG-2 encoders, including Cinema Craft. MainConcept - the encoder used in Premiere Pro and Encore DVD - came out on top.
Christopher Lefchik is offline   Reply With Quote
Old August 29th, 2006, 06:00 PM   #18
I have tried Canopus encoder straight out of Premiere and the problem is still there. To answer a previous question I do encode in 5.1 Dolby as I have bought the Surcode rights. Just to clarify, the size of the file doesn’t matter to me as long as my problem is corrected and I receive good quality video. Thanks
Daniel
Daniel Livschutz is offline   Reply With Quote
Old August 30th, 2006, 06:39 AM   #19
Yes, it depends
Yes Christopher - to quote you - it depends... the test Lars did lacks too many key "ingredients", so it might have brought out MainConcept on top on a certain type of footage, at a certain bitrate. Check out these pages for more complex tests with difficult to encode footage:
http://forum.videohelp.com/viewtopic.php?t=235665
http://www.tecoltd.com/enctest/enctest.htm
As Lars admits himself, he used default settings... apples to oranges...
Ervin Farkas
Ervin Farkas is offline   Reply
