How do I color correct in PPro? at DVinfo.net
Adobe Creative Suite
Old July 29th, 2006, 12:42 AM   #1
How do I color correct in PPro so I can change up the reds, blues, greens?
I moved the timeline bar to the clip I want to edit. Then clicked WINDOW > WORKSPACE > COLOR CORRECTION.
I clicked the EFFECTS tabs and looked through that and did not see anything. I clicked EFFECTS CONTROLS tab and did not see anything under that either.
Adam Bray is offline   Reply With Quote
Old July 29th, 2006, 10:15 AM   #2
What version of PPro are you using? The color correction options should be under the Video Effects folder in the Effects tab. It doesn't really matter what workspace you are in. Just highlight the clip you want to work on and apply the desired effect from the Effects tab. Once you've applied the effect, then you move over to the Effect Controls tab to adjust the effect in detail.
Sheila Ward is offline   Reply With Quote
Old July 29th, 2006, 10:21 AM   #3
In the effects window you choose:
Video Effects -> Image Control -> Color Corrector
Drop that effect on to your clip and then it will appear in the effect controls.
Barry Gribble
Integral Arts, IMDB
Barry Gribble is offline   Reply With Quote
Old July 29th, 2006, 06:51 PM   #4
OK, found it, thanks
