Shadow/Highlight Issue at DVinfo.net
Adobe Creative Suite
Old June 9th, 2006, 03:54 PM   #1
As i use this feature in photoshop on many of my images, i decided i would attempt to use it on some video footage. Today i tried it and the results were to say the least unexpected! I ended up with a posterized, greyscale effect. I tried rendering it and outputting it but nothing changed - Am i missing something incredibly obvious? Thank you for any response
Tim Johnson is offline   Reply With Quote
Old June 9th, 2006, 11:36 PM   #2
Hmmmmmm................ I've used this 'effect' and thought it worked quite well. Other than making the encode/render time horendous, the effect worked perfecto.
Can you explain a bit more?
Regards
JohnG
Nikon DSLR's finally a small 60P camcorder (Sanyo VPC-FH1)
John Godden is offline   Reply With Quote
Old June 10th, 2006, 08:32 AM   #3
here is a reproduction of the problem in photoshop.
http://i13.photobucket.com/albums/a2.../IMG_2965b.jpg
It is irrelevant if i render/output it as it remains the same?!
Old June 10th, 2006, 09:13 PM   #4
Wow! That's wild (but not in a good way).
It's working fine here, with DV and HDV footage - just like in photoshop. What is your input format? Do the other "Adjust" filters work OK?
Old June 11th, 2006, 02:18 AM   #5
yes every other filter works fine, its just shadow/highlight that comes out bizzarely. ive tried changing the input format with no luck, have no tried different resolutions though.
Old June 11th, 2006, 02:19 AM   #6
Tim,
That's weird, I haven't seen that. My first question would be, what's wrong with the original? It looks pretty slick? Just trying to get a little more details in the shadows/wheels, or something?
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply With Quote
Old June 11th, 2006, 05:54 AM   #7
Originally Posted by Joshua Provost
Tim,
Josh
was just an example of the problem.
(Wishes to be more informative and helpful than a nuisance)
