reverse page color in page peel... at DVinfo.net
Adobe Creative Suite
Old June 6th, 2006, 03:39 AM   #1
with the premiere pro built in page peel I cant work out how to change the colour of the reverse of the page (by default it is silver). I know in premiere 6.5 its shows a reflection of video track 1a (or b?!) on the page reverse but I cant see how to do it in premiere pro.
I have read up and I know you need to nest the sequence but cannot do this. I have set the sequence in and out points and now do not know what to do with it. In a premiere pro bible it says you should see the reverse of track A on the back of the page.. but there is no track A in premiere pro?!
If anyone could get back to me with the answer within the next 48 hours I'd be eternally greatful!
David J. Payne is offline   Reply With Quote
Old June 6th, 2006, 09:22 AM   #2
Use Page Curl
If you use the Page Curl effect instead (one of the GPU effects), it shows the back of the first image.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old June 6th, 2006, 12:53 PM   #3
excellent. thanks... do you know of any way to just get a blank colour or another picture entirely on the reverse?
Old June 6th, 2006, 01:50 PM   #4
Another picture? No. Blank color? We are back to using the silver of the Page Turn.
If you are enamored of special effects style transitions, I highly recommend finding a third party application.
I am certain that someone experienced enough with After Effects could figure it out. But check out the transition packages available and I think you'll find what you are looking for.
Steven Gotz
Old June 6th, 2006, 01:53 PM   #5
yeah i just thought it'd be simple to replace the silver colour with your own. I think I'll spend a bit of time getting into after effects.
thanks a lot for your help, it now looks much better with the page turn effect.
David
