#1216 |
Which version of divx are you using. I am using 5.2.1 and it load very slowly or not at all. Moreover, I was under the impression that if I installed Dr. Divx it would load the divx 5.2.1 codec as it said in the install. If I am wrong then would someone please tell me how I should go about this task.
Thanks |
#1217 |
I'm good to go now. Or at least good to start. Many thanks, Billy, you nailed it. I'm not sure what the default is for Premiere Pro but mine was a package deal with Canopus and it was factory set with Canopus DV as the default. Thanks again, Billy. And Ed, I wasn't ignoring your request for more info. I was preparing to answer you win Billy sent in the quick fix.
New to this community, I've got to say I'm impressed.
Randy |
#1218 |
How to improve quality of slow mo in Premiere?
Hi, i am using Premiere Pro 1.5
So far its great, i love all the new features, however, i have noticed that when i do slo motion by slowing down up to 50% the clip gets a mild case of jitters. It seems to vibrate. Does anyone have any good tips how to improve the quality of the clip and how to get rid of the jitters?
XL1s - P4 2.53Ghz - 1GB RAM - DVstorm2 - PPro 1.5 - AE 6.5 |
#1219 |
RED Code Chef
Which version of Premiere are you using Dwight?
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#1220 |
RED Code Chef
Is your footage/project in interlaced or progressive?
#1221 |
Go into your video options and check Flicker Removal this will fix the problem
"What Is Understood Need Not Be Discussed" |
#1222 |
Glad to help. Lord knows these guys sure have helped me out a bunch a times... Its nice to return the favor...
-Billy |
#1223 |
that did the trick... however i find that de-interlacing makes it better
#1224 |
deinterlacing is throwing away half your vertical resolution. I would definitely recommend just sticking with flicker removal.
#1225 |
Frame To Pic
How in premire pro do you take a frame that you want, and make it into a still picture?
Lif3 is an adv3nture to b3 liv3d, not a prob3m to b3 solv3d. -Alb3rt 3inst3in |
#1226 |
Premiere Pro:
The frame is exported from current time possition in the timeline window. Choose File -> Export -> Frame |
#1227 |
neither adobe or vegas can handle the trick. YOu need a special soft3ware to do those super smooth slomotions. 4 years the only way to do that was to use a expensive camera which shot a record-high amount of pics per second. Nowadyas you have programs like superslomotion and I don't remeber the name. I saw 3 topics about this. The thing is that de-interlacing will not help you. Superslomotion needs lots of pics per second. the more , the better. 24fps is not enough.
#1228 |
HI,
I have 2800 hz with 1024 ram and a profesional video card. I don't understand why it is so difficult for adobe and vegas to render the files in real-time. I am tlaking about playing back the movie without effects. I heard that was due to the pc monitor. PLaying it back thorugh a tv will not show those kind of artifacts. HEll. I have to buy a dvd recorder tojorrow. jeez. |
#1229 |
what will i need to capture from hdr-fx1 into premiere pro 1.5?
anything other than cineforms software? |
#1230 |
God on your side.....
None of the plugins work at this time. Cineform and Mainconcept both have upgrades to do. I suspect we will see upgrades in a couple of weeks. Sorry for the bad news DBK
Darren Kelly |
