Thread Tools
Search this Thread
#466 |
How to do a 24 style countdown clock in Adobe Premiere Pro or After Effects 6?
Any easy way to do this?
#467 |
24pa premiere plugin?
I have herd there is some sort of plugin for 24p advanced footage for premiere. is this true? whats it called?what version of premiere does this work in?
#468 |
"No Importer Found that Supports this File type"
Hi guys--I am trying to import an mpeg2 file that I have on CD into Premiere Pro, but I keep getting this error message: "No Importer Found that Supports this File Type." What gives? Obviously Premiere supports mpeg2,right? thanks for the help,
Peter |
#469 |
Does it play alright through windows media player? What sort of MPEG 2 file is it? What is its file extension name (*.mp2, *.mpeg, *.mpg....)?
Cheers,
Ed Smith Hampshire, UK Good things come to those who wait My Skiing web www.Frostytour.co.uk For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors |
#470 |
how to export without recompressing?
This is probably a dumb question but I am absolutely new to Premiere. Here's what I have: I shot my friends birthday and now I am trying to edit it. Since I don't have a list of all scenes with timecode I guess my best option is to capture it all together, right? Then I am trying to break this huge file into smaller ones that contain only one scene, so i put a big file in the timeline and cut it, then select small piece and go to "export movie" trying to save as a separate file. But it looks like premiere starts recompressing it again. I am afraid to lose quality doing this, so I'd appreciate your help. Is my procedure optimal for what I am trying to do? How to make premiere export without recompressing?
#471 |
It's called Premiere Pro version 1.5. Should be out soon.
#472 |
Air China Pilot
Try Gspot
Run the movie through this program and it will tell you if you have any codecs missing:
http://www.headbands.com/gspot/
-- Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery |
#473 |
RED Code Chef
With the latest version of Premiere you can also automatically
break up the clips while capturing (where you stopped and started the camera) like Vegas and Scenalyzer do. That can be handy depending on how you want to work. Premiere should not recompress, but that totally depends on the following: 1) your version of Premiere 2) your capture settings 3) your project settings 4) your export settings So tell us what you are doing at those 4 steps and we'll see if we can figure it out.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#474 |
RED Code Chef
I doubt it will also run with Media Player. The first question we
need answering is which version of premiere you are running...
#475 |
Hey guys--The file will play in Windows Media Player. I'm running Premiere Pro, I think version 7 (this is just a guess). I believe the file extension was .mp2, and I think we tried changing this to .mpeg hoping it would help, but it didn't. Perhaps we should try different file extensions? Thanks!
Peter |
#476 |
RED Code Chef
You can try .mpg but I doubt it will work. The question is what
kind of MPEG2 file it is. It can be an elementery stream, program stream or transport stream and I doubt it will read all three forms. Any chance this came from a digital sattelite / cable source and is an mpeg2 transport stream? Almost no programs can handle that format.
#477 |
Thanks for the reply Rob. I'm not sure specifically what kind of .mpeg file it is. It was output from Premiere 6.5 as an mpeg, so whatever Premiere outputs it as would be the format. I'm thinking I will just try to import it into Avid Xpress Pro and transcode it into something else, assuming Xpress Pro can understand it. I will report back with findings.
Peter |
#478 |
total training
I recommend you to go for the total training program. I heard it's very good. I didn't buy it coze it's too expensive for me.
http://www.totaltraining.com Ashfaq |
#479 |
RED Code Chef
It should be an elementery stream (only video) or a program
stream (video & audio normally) in that case. Strange Premiere does not want to read it back. I'm basically out of suggestions except for a re-install of Premiere (and perhaps Windows). Good luck!
#480 |
Thanks Rob. I think it is an elementary stream as it only contains video. I tried importing into Avid and it didn't recognize it either. We are going to try importing and transcoding in Cleaner, hopefully that does the trick.
Peter |
