Adobe Premiere & Premiere Pro discussions from 2004 - Page 30 at DVinfo.net
Adobe Creative Suite
Old May 4th, 2004, 03:00 PM   #436
It seems as though everyone pretty well covered the bases here, and I just wanted to throw in some words of encouragement. I too went from Pinnacle software over to Adobe Premiere about a year ago. I admit when I first tried Premiere I thought the interface was terrible and went back to Pinnacle right away. As I played around with Premiere more, I got more comfortable with it and began to use it 100% of the time. Just for fun, I reinstalled my old Pinnacle software, and that seems foreign to me now, you really how terrific Premiere really is until you drop back to the old editing software!!
I think that books and guides are a great learning tool, but what you may want to do is read up on some basics, and play around with test footage on your own. Everyone learns in their own way, I find that it helped me more to do my own thing to figure stuff out rather than read the book and do step-by-step sorts of operations. Of course, I don't use much of the finer capabilities of Premiere, and I'm now looking into some reading material for the specifics. Good luck!
Robbie Smolinsky is offline
Old May 5th, 2004, 06:32 AM   #437
Sorry to bring back an old post, but I think I have the same problem as described above?
http://photos.aushobby.com/camera_prob.jpg
Have a look at the red in the right hand corner.
Is a screen capture of the problems I am having. Is this the same thing?
Clint Newman is offline
Old May 5th, 2004, 11:20 AM   #438
Transition
http://www.petrovideo.com/images/eyetest.wmv
Does anybody know if there is a transition for adobe premier to achieve that blurred effect?
John O Brien is offline
Old May 5th, 2004, 08:24 PM   #439
Applying Video Effects
I have tried to apply video effects to my clips in the timeline with no success(I'm using Premiere 6). I drag and drop it on the clip and it opens up the relevant window to control the effect, so I alter the brightness(example) and I can see the effect working on the clip(still image). But when I go to play it in the monitor window it just plays normally with no effect. I have read the manual and can't see what I'm doing wrong. Can anyone help?
jon
Jonathan Posch is offline
Old May 5th, 2004, 09:07 PM   #440
Are you rendering the video? Before viewing the timeline, go to "Timeline" -> "Render Work Area" (at least, that's the way it's set up in 6.5). In mast cases, you will not see the effect take effect until you render.
John Britt is offline
Old May 6th, 2004, 02:45 AM   #441
Is there a red cross at the top corner of your preview monitor? Can you see your effect via Preview scrub (Alt while dragging the editline)?
As John has already mentioned it'll probably need to be rendered. Shortcut key for this is normally Return.
Cheers,
Ed
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old May 6th, 2004, 10:35 AM   #442
I don't know about a transition, but a gaussian blur effect through a track matte would be simple enough. Although a very slight fish-eye lens would make it even more interesting.
Steven Gotz is offline
Old May 6th, 2004, 11:19 PM   #443
PPro Timeline Blinks out
Whenever I seem to dbl-click (a clip or just about anything) in Premiere Pro the timeline and monitor windows disappear and I have just the blank background page. I can move the cursor down and eventually click and scroll and a slice of the timeline or monitor windows will reveal themselves, but only a slice as I move vertically. I have to close the app and reopen to get my windows back. (Calling up a custom workspace doesn't do the trick.) This has happened on both a RTX100 and a software only system. Any ideas as to why and how to avoid?
Eric Lagerlof is offline
Old May 7th, 2004, 04:09 AM   #444
Thanks Steven.
Old May 7th, 2004, 10:54 AM   #445
It sounds like what you have is called a redraw issue. I think it is tied to system performance. What type of machine is it running on?
Jonathan Stanley is offline
Old May 7th, 2004, 11:37 AM   #446
Also can you list your screen resolution and colour depth. Might have something to do with it?
Ed Smith
Hampshire, UK
Ed Smith is offline
Old May 7th, 2004, 01:08 PM   #447
This has happened on two different computer systems, with different display cards and monitors. And it has happened only in Premiere Pro. I gather this isn't some sort of common bug???
Old May 7th, 2004, 01:24 PM   #448
Oh, and one system uses an Nvida card, another a Matrox 400. I'm not there now, so I don't know the resolutions or color depths are exactly, except the owner of the RTX100 set it to whatever Matrox asked it to be set to. And they're both fast boxes, AMD 3200+ and I believe the other one is a 64 bit Opteron. I really think this is some sort of software issue (or extremely weird option!!!!)
Old May 7th, 2004, 08:01 PM   #449
So, if I reinstall, will I loose the Projects I have been working on in the Projects folder? I guess I should move those to another part of the drive, heh?
Thanks for your help. Most of my questions about Premiere get answered here without posting a thing.
Great site.
At full draw,
Tyge Floyd
Tyge Floyd is offline
Old May 8th, 2004, 09:10 AM   #450
Which transition is this?
Which transition was used on the title of this video?
It appears to be some kind of blur transition. Does PPro have a similar transition?
Ming Dong is offline
