Adobe Premiere & Premiere Pro discussions from 2004 - Page 10 at DVinfo.net
Adobe Creative Suite
Old February 7th, 2004, 08:59 AM   #136
Premier disk error (Disk full?)
Hey,
I was doing some editing yesterday and when I went to export I got an error stating "disk error (Disk full?)" Now I have a 160 gig hard drive with about 100 gig of free space so the disk is nowhere close to full. I even uninstalled and reinstalled premier and that did not fix the problem. I had been exporting fine untill yesterday and then it stopped. I did a search on dogpile.com and found what I hope is a permanent fix that you can see here
http://forum.matrox.com/rt2000/Forum6/HTML/002731.html
Have any of you had this problem before and what did you do to fix it? I held down ctrl and shift upon startup of premier and chose single track editing again.
Jason Brooks is offline
Old February 7th, 2004, 01:02 PM   #137
Adobe Premiere Fades Playback Choppy On T.V?
I used the effects controls panel for this, and used keyframes with opacity values to create the fades, it fades from white to white by the way, the fades come out choppy when played back on television. Can anyone explain how to fix or prevent this? Thanks.
Lyndon Golanowski is offline
Old February 7th, 2004, 02:54 PM   #138
I had the same problem once before. But I realized it was because my export settings were set to deinterlace everything. Make sure your settings are correct.
Dustin Waits is offline
Old February 7th, 2004, 03:45 PM   #139
I don't want it de-interlaced? I thought de-interlacing footage was good? or should I interlace footage when export to tape? also, if I do a project in After Effects, should I interlace it in after effects, and then again in Adobe Premiere? or should I keep it de-itnerlaced and interlace it in Adobe. Im so confused on interlacing etc. thanks for your help, please let me know what I gotta do with this interlacing stuff.
Old February 7th, 2004, 08:26 PM   #140
premiere pro rendering question
Some questions about rendering time..on premiere pro.
So is it also true that the more effects in the video the longer the rendering time is? and how do you define "a lot of effects"? like I was only using some built-in effects like transform, key filters and some other basic stuff on the video here and there, but it still took quite long to render..
Johnny Cheung is offline
Old February 7th, 2004, 09:24 PM   #141
Well, I have not had that exact problem, however I have had one like it when I was attempting to render, and that was fixed by resetting my scratch disks (Once in premiere you can go to edit-> prefrences-> scratch disks, or I assume the ctrl shift works) and just make sure there are folders for those items to go to. Guess you might have already checked that, hopefully that will fix it though.
Jeff Smallwood is offline
Old February 7th, 2004, 10:36 PM   #142
If your footage was shot interlaced then I would leave it like that unless you have a specific reason for deinterlacing your footage. For instance, sometimes it lowers the file size if you deinterlace a video to upload to the web. Or if you are trying to create an effect such as an old film effect or something. But in any normal occasion, keep it interlaced.
Old February 8th, 2004, 06:39 AM   #143
Interlaced footage displays half the horizontal lines in 1/60th of a second and the other half in the following 1/60th, to create the appearance of one image per 1/30th of a second, on a TV screen. Footage intended for TV playback should be interlaced. Deinterlacing often improves the visual experience of the same material when purposed for PC monitors and the web.
David Hurdon
David Hurdon is offline
Old February 8th, 2004, 06:58 AM   #144
Adam, have you checked the settings viewer? Often a difference between the project settings and the source clips (which will show up in red in the viewer) will create additional work in rendering.
And on the subject of rendering, in DV lingo rendering is the activity that creates temporary files describing the end result of adding effects, titles, etc. Exporting doesn't involve rendering, unless you didn't already render the project as you worked on it. An export of unrendered material can take a very long time.
David Hurdon
Old February 8th, 2004, 01:05 PM   #145
RED Code Chef
If I'm not mistaken ctrl+shift resets Premiere back to the factory
defaults. This would changes it's temporary drive [scratch]
settings as well.
By default it will write the temp files to your C drive. Now I'm
assuming that your video is on another drive or partition (the
one with all the free space) and you want to make sure Premiere
uses those for temporary stuff as well.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old February 8th, 2004, 01:57 PM   #146
Hi
How big is your file?
I have had that message when exporting large files in excess of the FAT32 format limitations but never on NTFS formatted drives.
Cheers
Andrew
PAL XL-1, DV Raptor, Premiere
TOTAL AMATEUR - DOING IT FOR THE FUN
Andrew Leigh is offline
Old February 8th, 2004, 02:26 PM   #147
The file is a 30 second video clip with transitions. I had exported it before and it was about 5 mg. I fixed it with the ctrl shift trick and it happened again last night. I did the trick again and presto. Back in business. I have heard that premier can be buggy. I hope this is not a constant problem.
Old February 9th, 2004, 09:54 AM   #148
Ryan and keith are right, although most people in the industry tend to use targa images when exporting a frame from video. I believe that you could also use the shortcut key Ctrl+m to open up the export frame dialog box.
Bare in mind though that it will only export out at tv resolution i.e. 720x576 pal 720x480 ntsc. These are low quality you'll probably only get a decent pint out at about A5 size.
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old February 9th, 2004, 02:03 PM   #149
You probably only want to speed up the video, not the audio clip :)
Director: http://www.mediathreat.com
John Threat is offline
Old February 12th, 2004, 08:12 AM   #150
Do you have a DV camera with AV->DV conversion? That would mean you could import the footage through the camera as DV footage and maybe that is easier for Adobe to work with?
Maybe the AVI from your capture card is not a DV avi and premier is converting this first? Just a though as I have never done it. The times you quote seem excessive as I had the same size project and it only took about 40 minutes to export. I had less efffects than you though.
Hope that helps you comes to a solution.
Donie
Donie Kelly is offline
