Good Grain Remover for Premiere Pro?
Hi,
Does Premiere Pro 2.0 come with any good grain removal effect on its' presets? I looked but didn't find any. If it doesn't come with any, which plugin would you recomend for getting rid of grain on premiere? I copied After Effects "Remove Grain" to the Premiere plugin folder but it didn't work. |
I have PPro 1.51, and I don't think it has a grain remover, only a grain adder (!). Apparently you have AE, so use that. It's a bit confusing, since you must specifically instruct AE to render the whole frame, not just the preview area. Use the minimum amount to clean up. But beware, this is a horrendously CPU-intensive operation. I can't recall off the top of my thatch, but it takes hours to do minutes of video! The result can be quite startling, though.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759 |
That is why I wanted to find a plugin for Premiere. It usualy renders everything much much faster than AE. I just woke up after a 8 hours render with Remove Grain and I found out what you that you need to specify the whole frame (too bad I didn't read your post yesterday)...so now I have half the video without grain and half with grain.
Boris Continuum Complete has a denoise effect that is very good.
Costs $$ though Jon |
#5 |
#6 |
I know you can remove grain through the DVD export feature by clicking options and selecting the check box. It blurs things a little, and is very CPU intensive, but previews indicate that it appears to produce decent results. I'm experimenting with it a little.
I guess if you're not exporting to DVD or similar it won't do you much good, but I thought I would throw it out there. |
