What I see is not what I get
What I see is not what I get. I am using Premier Pro. I complete a project within premiere and it looks just fine. It is not until I burn to a DVD that I find all kinds bugs. Flickering movement, clips that I program to motion play and then freeze at the end look just fine in Premiere, but when I watch the finished product on DVD I t amperes to jitter or snap just as it turns to a still. How can I work these bugs out before I burn if Premiere if dose not recognize the problems to begin with?
Thanks Guys Any help would be appreciated. |
In your export settings, did you change the field order from lower to upper?
Premiere Pro 2. Sony HC1E cam. Athlon 64 4000+. 2gig Corsair RAM. ATI X800 Pro AGP graphics card. 2X SATA drives dedicated to video as RAID 0 |
This sounds like it could be one of two problems:
A- Interlace flicker: This happens when you have horizontal, thin 1-pixel lines that have high contrast. You see this on CRT TVs, but not non-CRT display devices or CRT computer monitors. The happens because the refresh rate for each field is only ~30hz (30 times a second). The remove interlace flicker or de-interlace filter will fix this, at the expense of resolution. You can also try slight blur in the vertical direction. B- Reversed field order: This happens when one field is displayed before the other. So instead of seeing fields 1 2 3 4 5 6, you are seeing 2 1 4 3 6 5. My guess is that it's probably situation A. 2- To avoid problems like these, monitor your video on a CRT TV or broadcast monitor. They can be hooked up to your camera/deck, which is hooked up to your computer via firewire. In PPro, there should be external preview settings that control this. |
