Corrupt HDV with Premiere Pro on PC at DVinfo.net
Adobe Creative Suite
Old March 17th, 2006, 10:38 AM   #1
My setup:
Sony Z1
Dell Dimension P4 3.06 Ghz, 1.25 Gb RAM
Windows XP SP2
Lacie 260Gb Firewire drive
Adobe Premier Pro v1.5.1
I have used this setup very successfully to capture HD output (downsampled by the camera).
But when I try to capture HDV (Premiere is using the Cineform intermediate) only the first 9 seconds of each clip are perfect, then it goes very "blocky" (like a bad satellite signal).
Does anyone have an idea where I am going wrong?
I have read many people claim they can successfully import HDV with a lower spec machine.
Antony Meadley is offline   Reply With Quote
Old March 17th, 2006, 12:29 PM   #2
Which version of AspectHD are you using? There was a bug in early versions of 4 that affected capture ... corrected by 4.0.2.
Old March 17th, 2006, 01:13 PM   #3
I am not using AspectHD, just the Cineform converter that comes with Premiere Pro v1.5.1
Old March 17th, 2006, 02:42 PM   #4
Originally Posted by Antony Meadley
My setup:
Sony Z1
Windows XP SP2
1. More memory, possible help. Most are using 2 gig
2. Are you sure playback isn't problem ? Video card, etc.
3. Capture to firewire device could be creating conflict.. Try saving to an onborad drive to test.
Chris J. Barcellos
Old March 17th, 2006, 03:59 PM   #5
CTO, CineForm Inc.
For Premiere 1.5.1 that PC my not be fast enough for reliable capture. Aspect HD is far more tolerant, and supports a wide range of PC types, so you could try that free demo. If Aspect HD works you can at least rule out a fault with hardware, but I don't think more memory or a different graphics card will help.
