Please help. Will coninuing on from where I left off, after reinstall?? at DVinfo.net
Adobe Creative Suite
Old January 13th, 2006, 12:51 AM   #1
Please help!! XP SP2 prompts PPro 1.5 reinstall. Will I loose everything??!
Hello all. Have searched but have not found answer to this one yet.
Should be fairly straight forward but the project is very important and I don't want to take any unnecessary risks.
-After upgrading to XP SP 2 - upon launch Premiere Pro 1.5 is asking me to reinstall. Options are to 'repair' -(which gets me nowhere) or to 'remove all installed components' and install from scratch.
Premiere install is on D:
Premiere save files/projects are on E:
If I "remove all installed components" and then reinstall on D:, will some of the information that links/organises my current project be lost? or is it all in this project folder on the E: drive?
I need to be able to reinstall Premiere pro 1.5 and pick up where I left off on my current project.
Please help.
Thanks in advance
Anthony.
Anthony Milic is offline   Reply With Quote
Old January 13th, 2006, 03:09 PM   #2
I don't know about Premeire Pro but I have uninstalled and reinstalled versions 5.1c on my big NLE and 6.5 on my laptop and didn't lose anything. I was scared to death the first time I had to do it a few years ago but it fixed the problem and I didn't lose any projects or settings. Did you try the reset option first. You may not have to uninstall to fix your issue if you perform a reset.
Reset Procedure
www.dvinfo.net/conf/showthread.php?t=56197
James Emory is offline   Reply With Quote
Old January 14th, 2006, 12:56 AM   #3
Yes, removing and reinstalling was the only option remaining.
I went through with it this morning - without a glitch. All Premiere 'system' componenets were removed, and all projects were left unscathed.
Once I reinstalled Premiere, it even intuitively relinked to the projects.
All's well that ends well.
Old January 14th, 2006, 01:01 AM   #4
It's a goooood feelin' ain't it!!
