Adobe Premiere & Premiere Pro discussions from 2006 - Page 34 at DVinfo.net
Adobe Creative Suite
Old October 20th, 2006, 09:38 PM   #496
After Effect
Pete;
Thank You for taking the time to reply. Pete I have a Pentium 4 3.00GHz with 1 GB of Ram This is an Acer Lap Top with a 7200RPM hard drive.
My computer is up to date with Windows programs. But I'm taking you advice and will go to Adobe forum for help.
Mike Quinones is offline   Reply With Quote
Old October 21st, 2006, 02:39 PM   #497
Is the audio preview rendering in the bottom corner of the screen?
http://www.darkbyke.deviantdesign.ca
Canon Elura 65
Adobe Premiere 1.5 Pro
Song VAIO PC / 3GHz / 1.5GB ram / 710GB capacity
Calvin Wallace is offline   Reply With Quote
Old October 21st, 2006, 05:12 PM   #498
Sounds like you have the audio playing out to the capture device. Check your settings.
Capture window, capture settings, general, playback settings,,,,, then audio settings. To check this out to see if that is it, just disconnect your capture device and play the footage.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old October 22nd, 2006, 05:08 AM   #499
Restoring Sequence?
Lets say I have a couple of sequences in my project bin, all nested into a master sequences...If I accidentaly delete a sequence from the project bin, it will obviously be deleted from the timeline, but how (besides an Undo) can I re-import the sequence into the project bin or am I forced to re-edit that sequence? Also, is there a way to lock assets in the project bin so I don't end up deleted them by accident?
Aviv Hallale is offline   Reply With Quote
Old October 22nd, 2006, 07:35 AM   #500
I'm pretty sure it's gone completely if you deleted it from the project bin.
Canon Elura 65
Old October 22nd, 2006, 08:12 AM   #501
First, I would put all of my assets in different folders, Video clips, music, titles, etc. so that you don't confuse sequences with other assets.
Second, I'm not sure why you would object to using undo, but another option would be to exit the project without saving the changes to it.
Mike
Old October 23rd, 2006, 02:48 PM   #502
Just use standard 4x3. Import footage, interpret as 4x3 and you'll have black bars on top and bottom, without an extra stretch.
Bram Corstjens is offline   Reply With Quote
Old October 23rd, 2006, 03:06 PM   #503
What's safe to delete?
When a project begins to take up too much space, which of the Premiere generated folders - Adobe Premiere Pro AutoSave, Adobe Premiere Pro Preview Files, Encoded Files and Media Cache files - are safe to delete without affecting the project?
These folders can start running into the gigs.
Old October 23rd, 2006, 03:09 PM   #504
That fake widescreen fiasco really does more harm than good, especially when working with blurs and the actual psuedo-letterbox gets blurred too.
Old October 23rd, 2006, 05:05 PM   #505
what is Your reason?
It depends mostly of Your reason to delete. When i'm backing up my project i always delete previews and conformed audio but there's no reason to delete auto save because it takes so little hd space.
If You don't want to startup slowly next time You can't delete conformed audio because premiere will conform audio if he found something unconformed and we all know how painful waiting it is but nothing more...
And if You don't want to loose rendered parts in timeline don't delete previews because sometimes genereting previews may take hours.
Frank Hool is offline   Reply With Quote
Old October 24th, 2006, 06:23 PM   #506
Got it figured out. I have to say that once I got it figured out, it worked great. Really quite simple. In fact, I didn't realize what I had missed. Even with the footage that was not one continuous time code, I had no problem, and I even added a sound track from my HiMD player.
I got some heat on a Vegas thread about how difficult it was to do in PremierePro. Not sure why they were saying that from this experience.
Chris J. Barcellos
Old October 24th, 2006, 08:32 PM   #507
Any compatibility issues between PPRO1.5 and PPRO 2?
I am near the end of a short film and I am tempted to upgrade from 1.5 to 2 (color correction sounds nicer), has anybody had any problems with their projects form 1.5 in 2???
thanks
Jack Jenkins is offline   Reply With Quote
Old October 24th, 2006, 08:39 PM   #508
I haven't tried it, but I would actually save the project by another project name if I was going to try it.
Chris J. Barcellos
Old October 24th, 2006, 09:31 PM   #509
thanks
I uninstalled PP 1.5.1 last week and loaded up my new PP2 premium bundle. All of the old projects were there and opened without a hitch. No problems!
Mike
Old October 24th, 2006, 09:53 PM   #510
cool, that was fast!
thanks guys
