#436 |
Hi George,
My TV has a setting to do the same thing - 'Panorama' FWIW it can be OK but is distracting when you pan, and if you are having composition with subjects set 1/3 or less from the frame edge. Sorry - can't help with the plugins. Cheers. |
#437 |
Kyle:
Funny you should be the one to reply first. This all came about because I'm shooting some material for Australian television. The producer is requiring 16:9 since all TV is 16:9 in your country. Is this really the case? Currently I'm needing to rent a camera to complete the work but they did offer to look at a conversion from 4:3 to 16:9.
"the difference between an amateur photographer and a professional is the amateur shows you all his pictures" |
#438 |
I prefer not to normalize audio in premiere (does not seem to work right all the time). I would start with the audio mixer and get as close as you can to what you want. Then export audio only, bring it into adobe audition (or back into premiere), and normalize that audio clip.
Exporting to tape, just plug in camera, set to VCR mode, and click export to tape.
http://wildlookout.com |
#439 | |
As far as I know there is no difference between the "Educational" and regular version.
#440 |
Premire Pro and Panasonic MXF
I shot some footage for a client and gave it to them on a HDD, they are editing in Premiere Pro 2 and can't figure out how to import it.
We are a mac based post facility so I have no idea how Premiere handles this. According to Adobes web site it will except P2 MXF, but they don't explain how to do it. The clients not an editor and I can't convince them to just let us edit it. Does anyone no how to import MXF Files into Premiere Pro 2 off a HDD |
#441 |
George,
I wouldn't say all TV is 16:9, but almost all new programs are broadcast 16:9 on digital (HD and/or SD) and while analogue used to always be full frame 4:3, more and more is being shown letterboxed to 14:9 - Although the only time I watch analogue is when I visit my folks so that might not be current anymore. Personally I hate watching a good, new program in 4:3 - especially on my widescreen TV... BTW regarding the panorama thing - I thought I'd use it a fair bit, but I found I didn't really like it. If I get a DVD or something that is 4:3 I just watch it in 4:3. Panorama is too distracting, I'm always watching the edges of the frame to see what's out of proportion. Cheers. |
#442 |
Capturing DVX 30p footage as 24P
Is this a problem? I've read various reports,most saying it doesn't matter...Although I'm not sure....
I've just discovered the option to do custom project settings...Is it better to start from the DVX 24p setting, and just change the framerate to 29.97? Will that give me a proper capture???? Thanks... |
#443 |
Wayne, the problem with normalizing a clip in PPRo is that it looks at the highest level in the clip and lifts the audio gain in the clip enough to bring that highest bit to 0db. For example, you record people around a table and most of the dialog is very low but someone thumps a glass down on the table loudly. Normalizing the clip may bring the gain down to make sure the thump of the glass is at and not above 0db, making the dialog even quieter. Just to say, unless the audio levels are consistent, longer clips may give you more problems when normalizing.
You can normalize long clips in the project window before they get cut up in the timeline, and that will save you having to normalize each smaller instance of the clip later. You might want to explore the compressor as well for level adjustments. Having said that, and keeping in mind that I agree with the above post about using the mixer, you can, in PPro, use the expanded mixer and set dynamic effects in the track mixer. That will set the effect for the whole track as opposed to doing it for an individual clip. |
#444 |
What for?
If you need it, you can try exporting the edited footage and then replacing the sequence with the rendered version but you loose the editability then. |
#445 |
more lines
i've asked this once before, but i have to bring it up once more.
notice the lines in this frame grab, i cant get rid of them. i dont know if it's happening on capture or what. i am about to prepare for my cut and ingest all of this stuff for my flick and i obviously cant have these lines. i've tried to export to tape and see if the lines would disappear on a standard tv but they are still visible. anyone have any thoughts on this? thanks in advance. |
#446 |
Are you talking about the black bars on the sides?
#447 |
yeah, sorry.
any clue? i've been using premiere for a long time and never had this problem. feeling stupid.... |
#448 |
I would simply increase my horizontal width.
#449 |
M&E track requirement
We have just made a sale to a TV network in New Zealand. They want Digital Betacam masters with stereo or dual mono on tracks 1 and 2 and M&E on Tks 3 and 4.
The trouble is that in the project, I have placed live location sound on audio 1 and that includes stereo and mono sound. On audio 2 I placed a mono voiceover and on audio 3 I placed stereo music. The question is how do I get to TV requirements without a sound sweetening session using Premiere Pro 1.5? How can I produce dual mono? |
#450 |
Synchronizing audio and video
When I make a photo montage in Premier Pro the first thing I do is listen to the song and tag the beats and measures on the timeline. Then I tag the climax of the song. By doing this I am able to have the photos change to the beat of the music, and then let loose at a drum fill. It works really good inside Premier. However, when I burn to DVD it seems as if the drum sync does not line up when watching the finished product. What is causing this problem?
Any help would be appreciated, Al Ioimo. |
