Adobe Premiere & Premiere Pro discussions from 2006 - Page 26 at DVinfo.net
Adobe Creative Suite
Old September 10th, 2006, 12:24 AM   #376
In 1.5, when you transcode and select mpeg for DVD, it will render separate files for video and audio, unless you opt for "DVD" in the Multiplex menu when you are selecting to transcode on export to your mpeg file.
Chris J. Barcellos
Old September 10th, 2006, 07:16 AM   #377
playing a clip and having it freeze for dramatic effect...
in pp2 how do I play like a 6 sec clip in slow mo and have the scene freeze at the end for another couple seconds?
Mark Leonard is offline   Reply With Quote
Old September 10th, 2006, 08:32 AM   #378
Make a copy of the slow-mo file, place it right after the slow-mo file, right click on the copied file, select frame hold, set frame hold to hold on last frame.
I think :)
Jon Jaschob is offline   Reply With Quote
Old September 10th, 2006, 08:43 AM   #379
Per "PPro 2.0 Bible"...
You can freeze on either an in-point, out-point, or a marked point.
1) select/left-click the clip
2) if you want to freeze on something OTHER THAN an in or out point, set unnumbered marker in Source Monitor
3) Choose Clip/Video Options/Frame Hold (that opens the Frame Hold Options dialog)
4) from that, choose either in-point, out-point, or Marker 0.
5) Click the Hold On check box
6) to prevent keyframe effects form being viewed, click Hold Filters check box.
7) To remove effects of deinterlacing, click the Deinterlace check box.
Denis
Our actions are based on our own experience and knowledge. Thus, no one is ever totally right, nor totally wrong. We simply act from what we "know" to be true, based on that experience and knowledge. Beyond that, we pose questions to others.
Denis Danatzko is offline   Reply With Quote
Old September 11th, 2006, 02:05 AM   #380
Chris,
Thanks for the fast response!
I set it for DVD on the Multiplexing and problem solved. Thanks again, really appreciated.
Steve Wolla is offline   Reply With Quote
Old September 11th, 2006, 03:21 PM   #381
Internal HD monitoring?
I'm looking at a monitoring solution for offlining a very-low-budget feature, shot in HDV 720@24p. My concerns are soft focus and framing, and a good viewing experience for me and the director.
It seems to me that the best choice is a high-rez LCD, now that you can get nice ones for $300. Any serious HD monitor, consumer plasma screen or projector would cost way more, and from looking at specs, the latter two don't even have true HD resolutions.
Since the project is 1280x720, could I enjoy an up-rezed full-screen display and still judge focus properly? Can I monitor directly from the computer with PPro? Does it support a full-screen mode at all?
Drew Lahat is offline   Reply With Quote
Old September 12th, 2006, 11:06 AM   #382
Premiere thinks 4:3 footage is 16:9
I'm wanting to make sure that working 4:3 footage in a 16:9 project will work before I get started. Can someone tell me how Premiere tells 4:3 footage from 16:9? How does that work?
This is in regards to this post:
http://www.dvinfo.net/conf/showthread.php?t=74777
I'm doing everything in SD. Thanks for any help!
(insert long list of expensive stuff)
Jeff Miller is offline   Reply With Quote
Old September 12th, 2006, 02:07 PM   #383
Hi,
You have the "Interpret footage" option in Video menu, or available via right-click. There you can set the pixel aspect ratio.
The problem with 4x3 footage in 16x9 project is that you have to upscale it in the timeline to match 16x9 resolution (roughly 720->1024 pixels). This will decrease the quality.
Bart Walczak is offline   Reply With Quote
Old September 12th, 2006, 03:16 PM   #384
Thanks Bart, will check that out. It seems to work ok except that Premiere seems to have confused some footage's aspect ratio.
I'm not too concerned about the res; I'm not going to stretch the 4:3, I just want it to play properly on a 16:9 TV without having to take the tv out of 16:9.
Old September 12th, 2006, 03:17 PM   #385
Making DV look more like film
Hello - I was wondering if anyone had tips or methods in making DV footage look less like DV and more like film. For the most part, I'm looking to add grain, make it look worse than it currently is, but in a stylish way - more analog, less digital - kind of like an old 8mm film. Suggestions would be great. I use adobe premier pro 2.0 and don't use after effects, so I'm mainly looking for methods that involve changing settings within premier.
thanks!
Nic Brown is offline   Reply With Quote
Old September 12th, 2006, 03:52 PM   #386
There's a whole forum on that topic, right here, with 7000+ posts!
Not all involving Premiere, admittedly, but the search box is your friend...
http://www.dvinfo.net/conf/forumdisplay.php?f=34
Old September 12th, 2006, 03:55 PM   #387
I can't seem to find any relevant info at that link you gave... thanks anyways. anyone have any other ideas? Keep in mind, the footage i'm using is run of the mill 29.97 fps DV AVI.
Old September 12th, 2006, 09:22 PM   #388
quicktime import ??
will premiere import quicktime files??
Rob.
www.rpbproductions.com
robert@rpbproductions.com
HD101/G5 Mac/4gig Ram/1TB HDD/30" Cinema Display/FCP.
Robert Bale is offline   Reply With Quote
Old September 12th, 2006, 10:19 PM   #389
Yes, but it likely won't edit in real time.
Chris Harris is offline   Reply With Quote
Old September 13th, 2006, 12:45 PM   #390
Take a look at the forum that you were referred to. It has TONS of tips with how to do each of those things in different threads.
http://www.sareen.tv
Aanarav Sareen is offline   Reply
