Can I edit MOV files from Atomos Ninja V in Premiere Elements 2018 at DVinfo.net
Adobe Creative Suite
Old August 9th, 2019, 07:21 AM   #1
Hi there, I did a video shoot today and the main camera was a Fuji XT3 and recording into an Atomos Ninja V. The shooter gave me the MOV files but they show up a green videos in Premiere Elements 2018.
Please advise what I need to do in order to edit the files.
Ronald
---MediaInfo---
General
Complete name : D:\2019-08-08 Natural Life photos video\Atomos Ninja\NINJAV_S001_S001_T001.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 148 MiB
Duration : 10 s 969 ms
Overall bit rate mode : Variable
Overall bit rate : 113 Mb/s
Encoded date : UTC 2019-08-08 14:14:42
Tagged date : UTC 2019-08-08 14:14:42
Writing library : Apple QuickTime
com.atomos.hdr.gamut : Rec709
com.atomos.hdr.gamma : Rec709
com.atomos.hdr.monitormode : Native
com.apple.proapps.image.{TIFF}.Make : Atomos
com.apple.proapps.image.{TIFF}.Model : NinjaV
com.apple.proapps.image.{TIFF}.Software : 10.01
Video
Format : ProRes
Format version : Version 0
Format profile : 422
Codec ID : apcn
Bit rate mode : Variable
Bit rate : 109 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Progressive
Bits/(Pixel*Frame) : 2.187
Stream size : 142 MiB (96%)
Writing library : atms
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : in24
Bit rate mode : Constant
Bit rate : 4 608 kb/s
Channel(s) : 4 channels
Sampling rate : 48.0 kHz
Bit depth : 24 bits
Stream size : 1.51 MiB (1%)
Language : English
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 00:00:00:00
Time code, striped : Yes
Language : English
Ronald Lee is offline   Reply With Quote
Old August 9th, 2019, 12:11 PM   #2
Re: Can I edit MOV files from Atomos Ninja V in Premiere Elements 2018
*Solved*
The codec is the Apple Prores codec. My computer is a PC. Handbreak converted it, as did installing Quicktime.
Old August 9th, 2019, 12:16 PM   #3
Thanks for following up on this, Ronald -- much appreciated!
Old August 10th, 2019, 05:10 PM   #4
Handbrake is not the solution.
This is and installing QT
https://helpx.adobe.com/premiere-ele...es-issues.html
But gathering you already know this from the Adobe forum.
ACE Premiere Pro CC
Adobe Community Professional
Ann Bens is offline   Reply
