Upgrading to Win 10 PPRO CC & Dual Boot SYS - Page 3 at DVinfo.net
Adobe Creative Suite
Old June 22nd, 2017, 03:29 PM   #31
Re: Upgrading to Win 10 PPRO CC & Dual Boot SYS
No point in contacting Adobe on CS6: its not supported anymore. They will direct you to the forums.
If you want good advice on hardware start here:
https://forums.adobe.com/community/p...hardware_forum
ACE Premiere Pro CC
Adobe Community Professional
Old June 22nd, 2017, 03:33 PM   #32
Proper way to uninstall CS6 is to use the Windows Control Panel.
Then use Cleaner Tool.
ACE Premiere Pro CC
Old June 22nd, 2017, 04:46 PM   #33
Thank you Luke:
Now it's becoming clearer.
Best Regards.
Harry
Harry Lender is offline   Reply With Quote
Old June 22nd, 2017, 04:49 PM   #34
Thanks you so much Ann. You and Luke made it much clearer.
Best Regards
Harry
Old June 22nd, 2017, 09:13 PM   #35
Luke and Ann;
In the midst of doing all my research it suddenly dawned on me, Why should I Uninstall and Reinstall CS6?
Even though CS6 has a small error I never really intended on using it again once I installed Premiere Pro CC. And it might open up doors that should remain closed. I like what CC has to offer so why go back and use CS6.
Uninstalling and Reinstalling might be more trouble than it's worth. I might just "leave well enough alone."
Your thoughts.
Thanks again for all your help.
Harry
Old June 24th, 2017, 08:24 AM   #36
I think once you experience the improved features in Premiere Pro CC 2017 you will have no further use for CS6
Luke Miller is offline   Reply With Quote
Old June 25th, 2017, 04:24 PM   #37
I would leave CS6 on the computer for a while; just in case....
like projects that wont convert properly,
sd mpeg2 can have issues in CC.
ACE Premiere Pro CC
Old June 25th, 2017, 07:53 PM   #38
I finally did make that decision. I'm intending on Upgrading Win 7 to Win 10 leaving CS6 on the computer. Then getting a new Hard drive and installing Premiere Pro CC on to that Hard Drive by itself. My only worry is if I would open up my project that I constructed in CS6 would it bring over the same error that I had in CS6. I'm planning on reconstructing that project all new and fresh to avoid that possibility.
Anyway Thanks So much for your help. I'll be making the big move after July 4th. when my computer tech gets back from vacation.
Regards
Harry
Old June 26th, 2017, 02:31 PM   #39
All programs should reside on the boot drive (C drive)
ACE Premiere Pro CC
Old July 7th, 2017, 01:00 PM   #40
I have a question. Next week I'll be upgrading to Win 10. Also I'll be moving from Adobe Premiere Pro CS6 to CC. I won't be uninstalling CS6. As mentioned earlier in this post I had an error in the settings that I couldn't find and correct. My question is, If I had a project that I was working on in CS6 and opened it in CC would the problem come over from CS6 to CC? Or would it be better to reconstruct that project from scratch in CC.
Again Thanks so much for everyone's help.
Harry
Old July 7th, 2017, 02:07 PM   #41
Start fresh in CC.
ACE Premiere Pro CC
Old July 7th, 2017, 05:17 PM   #42
Thank you so much. Will do.
Old July 15th, 2017, 04:34 PM   #43
To All,
Just to let you know. Just upgraded from Windows 7 too Windows 10. Did the upgrade without reformatting the HD. Everything went perfect. Also Installed Premiere Pro CC. Installation was perfect with no problems.
I wish to thank everyone for help and suggestions. I am eternally grateful.
Thanks Again
Harry
