Using a gradient mask at DVinfo.net
Adobe Creative Suite
Old May 30th, 2014, 07:15 AM   #1
Hi All - I have a shot that is correctly colour balanced down the left hand side (near some windows) but too warm down the right (lots of tungsten lighting) I want to colour correct the overly warm clip and then overlay it onto the clip that is correct and merge them together. I've tried using a gradient title and track matte but to no avail - what am I missing? I can do it with a four point garbage matte but would need a feathered edge for it to work properly
I can also get close using the Linear Wipe effect but the feather is not enough
Pete
Old June 1st, 2014, 11:02 PM   #2
Re: Using a gradient mask
Check out the Creative Impatience plugins - free to download - which include a feathered crop and power window. This set of plugins solves one of the biggest bugs of premiere for me - the fact that even the simplest gradients/masks/vignette's are a pain to create in Premiere. You might be able to use their feathered crop to gradient/mask your problem areas.
Otherwise, the obvious solution is a quick trip to AE, if you have it.
Wasn't masking/feathering one of the new features added or announced for Premiere in the most recent CC upgrade? I'm still on CS6 but this could be a big time saver for me and one of the things that finally gets me to upgrade.
John Wiley is offline   Reply With Quote
Old June 2nd, 2014, 04:59 AM   #3
Thanks John - I'll get those plugins now - I could go into AE but I do get this quite often as I shoot weddings and a lot of reception rooms have strong daylight down one side and warmer tungsten the further you go into the room - at doing nearly a wedding a week I don't want to do anything to extend the time of my workflow.
I'm on CS5.5 and won't at the moment be upgrading to CC (not even sure there's an upgrade path for exosting owners) as I really don't believe in renting software
Thanks for the tip - I wouldn't have thought something that should be so simple is a pain to do natively!
Pete
Old June 2nd, 2014, 09:33 AM   #4
<< I've tried using a gradient title and track matte but to no avail >>
You can drop a Fast Blur on the title shape for feathering.
ACE Premiere Pro CC
Adobe Community Professional
Old June 8th, 2014, 07:38 AM   #5
Creative Impatience - Feathered Crop - Absolutely brilliant!!! And free - I will so donate as it is a time saver for me!
Old June 9th, 2014, 08:10 PM   #6
Glad I could recommend it! It can be a big time saver for those things that are too basic to deserve a trip to AE.
