Encore motion menu softer than static! at DVinfo.net
Adobe Creative Suite
Old February 19th, 2014, 10:10 AM   #1
Anyone noticed this? I preview a menu and all is fine, but then select 'animate buttons' and once it's rendered it is noticeably softer - specially any button text.
Is there a way of getting to the encode settings for the menus to up the quality/bit rate?
Cheers
Pete
Old February 19th, 2014, 03:01 PM   #2
Re: Encore motion menu softer than static!
With dvd its usually a fields issue depending on
Which Encore, what is your source, DVD or BD, DL used?
ACE Premiere Pro CC
Adobe Community Professional
Old February 21st, 2014, 03:46 AM   #3
I'm using Encore CS5, My footage is 1920X1080 AVCHD from Sony NEXCAM. I output to both DVD and Blu-ray
It's not badly blurred and I'm sure most people would not notice it - I guesss I'm pixel peeping but it is ever so softer once rendered.
Pete
Old February 21st, 2014, 09:01 AM   #4
For CS5 do not use DL as it flips the fields (hence the blurred thumbnails).
Export from Premiere directly to mpeg2-dvd and import that into Encore.
For BD you can use DL. I never did.
ACE Premiere Pro CC
Old February 21st, 2014, 10:40 AM   #5
That's how I do it Ann - my issue is with the editable menu text in Encore - If I have a static menu the text is nice and sharp but If I have video thumbnails and create a motion menu - the rendered text becomes blurred. There seem to be no settings over the motion menu render to maybe increase the bit rate for example.
Old February 21st, 2014, 01:23 PM   #6
Long shot. Assuming you're using After Effects to make the motion menu? Right click the composition window, be sure frame blending is Off....like I say, long shot....
Battle Vaughan is offline   Reply
