Best way to color correct Gopro Protune? at DVinfo.net
Adobe Creative Suite
Old February 16th, 2014, 07:13 AM   #1
Have a Gopro hero 3+ Black Edition. Use Protune.
Have not doing so much color correktion in Premiere Pro CC.
Can you explain in detail how to do this best?
Possible to da å presset to use agai and again?
Maybe a plugin?
Canon 5DmkIII, Canon 7D, EF85 1.8, EF 100 2.8LIS macro, EF135 2.0, EF 17-40 4L, EF 24-105 4L, EF 70-200 2.8LIS II, EF 70-200 4LIS, Tamron 24-70 2.8, Sigma 50 1.4, Sigma Art 35 1.4
Arve Hansen is offline   Reply With Quote
Old February 16th, 2014, 08:43 AM   #2
Re: Best way to color correct Gopro Protune?
I would recommend using the GoPro utility as a start. It has a protune setting in the software that corrects for the flat image. You can use that to help you establish a preset in your editing program to do the same thing.
How:
1. Export a clip from the GoPro utility that has the ProTune preset applied and import that into your editor.
2. Bring in the same clip straight from the camera.
3. Use the color correction utility in your editor to match them up.
That will give you a basic preset to edit from and continue the grading process from.
http://www.LandYachtMedia.com
Old February 16th, 2014, 09:00 AM   #3
Just a word of caution, I would make sure if you use the GoPro software, that you have a rollback point on your computer. There have been a number of experiences, including myself, of the software moving a system .dll to a different location, preventing some programmes from loading or running properly.
Roger
Roger Gunkel is offline   Reply
