Help a Final Cut Pro user since FCP1.0.2 migrate to Premiere CS5.5 at DVinfo.net
Adobe Creative Suite
Old March 5th, 2013, 09:49 PM   #1
Hi folks... As the title indicates, I've been an FCP editor since 1.0.2, currently on 7.0.3 on a 20 month old iMac running OSX10.6.8
Before that, I was an AVID Media Composer 6 (The ORIGINAL 6... I can't keep up with their naming... running on old beige Apple G3 350MHz with Meridien cards...) and later a (poor) Media100 editor.
I work predominantly with a combination of three-point editing and drag-and-drop-to-the-timeline, depending on WHAT I'm editing.
I also use split 2 channel audio routinely where I'll have a lavaliere mic on one channel and an overhead shotgun on another.
I use Sony EX series (EX1, EX3...) cameras and FS series (FS100 and FS700) cameras predominantly with the occasional dSLR footage or GoPro footage.
I'm a verité videographer, not a filmmaker. Broadcast documentaries, training/best practices videos, typically long form.
I currently use a Matrox MXO2LE as my analog and digital IO device in FCP.
My QUESTION is: can someone with similar experiences point me in the right direction for resources to help with this transition? I've already looked at the sticky that links to the Adobe site with hints for FCP users.
The workflow is VERY different on the surface, especially around track manipulation.
ANY help is MASSIVELY appreciated. I didn't even know WHAT to start searching for here at DVInfo.
Old March 6th, 2013, 09:37 AM   #2
Re: Help a Final Cut Pro user since FCP1.0.2 migrate to Premiere CS5.5
I recently made a transition from Sony Vegas and have found all the help I need on YouTube and Vimeo. Adobe software isn't always intuitive but after watching a few tutorials a day I'm getting up to speed.
Duane Adam is offline   Reply With Quote
Old March 6th, 2013, 10:42 AM   #3
Recommend lynda.com, extensive tutorials for very reasonable subscription price. Also select the fcp keyboard shortcuts option, unless you want to go cold-turkey and learn the Adobe shortcuts....
Old March 6th, 2013, 11:16 AM   #4
Good start folks.
Battle, I've already enabled the FCP shortcuts, thanks. I keep forgetting about Lynda.
Guess I'm just hoping there is a clear and CONCISE knowledge repository for folks leaving the FCP ship and not having to "relearn" new software... Hoping for a MIGRATION path, I suppose.
I'll check Lynda later this morning.
Old March 6th, 2013, 11:17 AM   #5
For example, like this:
Migrating from Final Cut Pro 7 to Premiere Pro | Video Tutorial from lynda.com
Thanks Battle.
Old March 6th, 2013, 02:33 PM   #6
Workflow for Final Cut Pro users | Adobe Premiere Pro CS6
Learn Premiere Pro CS6 | Adobe TV
ACE Premiere Pro CC
Adobe Community Professional
Old March 6th, 2013, 06:46 PM   #7
Thank you, Ann. I think those will work very well for me.
Old March 6th, 2013, 11:02 PM   #8
You also might download the Premiere Pro CS5/CS6 reference manual here: http://helpx.adobe.com/pdf/premiere_pro_reference.pdf
And this is pretty useful, right here on dvinfo.net articles section: http://www.dvinfo.net/article/post/t...p-editors.html
There are a lot of specifics you may want to refer to in the Premiere reference --- the three and four point edits, and drag-and drop that you mentioned, for example, are explained step-by-step. You can access the same information live on line from the help tab in the program, as well. The Adobe TV tutorials for Premiere (as well as many other Adobe products) are generally well done and helpful. I was an FCP 7 user at my last job, the transition to Premiere is not as daunting as it looks --- the details are different, but the programs are basically pretty similar. Not at all as hard (imho) as figuring out Final Cut X. ... best wishes with your change, this is a pretty helpful bunch on the Adobe group....
Old March 7th, 2013, 12:06 PM   #9
Again, I thank you Battle for your generous contribution to helping me migrate.
I figured a lot of the information would be here but wading through was going to be daunting.
If you are at NAB this year, I owe you a beverage of your choice.
Old March 7th, 2013, 01:16 PM   #10
Thanks, much appreciated, I won't get there but hoist one for the Adobe thread, we're here to help!
