Asking for a friend Premiere Pro CS6 problem. at DVinfo.net
Adobe Creative Suite
Old February 25th, 2013, 08:18 PM   #1
I have tried to help her but for the LIFE of me I am stumped (but I am new to CS6 just upgraded). Here is her question C&P'ed from an Adobe forum:
I'm a new user, but from what I understand I am doing this correctly, I had a friend come over who is familiar with the program and she couldn't figure it out.
I am trying to insert a series(about 10) jpg images from my d800 camera into my timeline. that works fine. I have tried this full size, fit to frame, and I have manually resized, I have also tried a tiff file just to see. Once the jpg is in the timeline, it shows up black in the project window.
I rendered it to see what would happen, and htey were there, but it's really frustrating not having them there now while I"m trying to put the movie together to see if they fit.
Also, I just tried to adjust the brightness through effects on a video clip, and then after doing that the video clip plays mostly black with a bit of strobing.
Does anyone know what is going on? I"m super frustrated and would appreciate any guidance available.
Any advice??
Kelsey Emuss is offline   Reply With Quote
Old February 25th, 2013, 09:12 PM   #2
Re: Asking for a friend Premiere Pro CS6 problem.
What sort of configuration is the computer? This sounds like it could be a display card or display card driver being a bit finnicky...if the system is also limited on RAM, redrawing the JPEGs may be more work than the computer can do since the scaling on the stills is probably intense.
I wonder how it would work if you loaded the images into Photoshop and decrease their size (I assume they're quite large).
TimK
Kolb Productions
Tim Kolb is offline   Reply With Quote
Old February 26th, 2013, 08:42 AM   #3
Not sure...but what you are saying makes sense. I once had a video card issue and it only affected my project window! Will pass it on! Thanks!
Old February 26th, 2013, 09:46 AM   #4
You say you're new to CS6, did you update after you installed it? The versions on the Adobe website and on discs are older. I can bring full size D800 jpeg, png or photoshop files into the timeline and they all appear in the project window.
Duane Adam is offline   Reply With Quote
Old February 26th, 2013, 12:30 PM   #5
Probably not the cause in this case, but make sure the .jpegs use RGB color, CYMK will show up black in Premiere.
Also, if the stills are super-huge, try scaling them down before import, such as 1920x1080 for HD.
As suggested, make sure CS6 is up to date, for PC will be 6.0.3 and 6.0.2 for Mac.
Jeff Pulera
Safe Harbor Computers
Old February 26th, 2013, 01:23 PM   #6
I'm not the one having the problem...a friend is. I mentioned being new to 6 because due to my newness (I have only used CS3) I can't seem to help her??
Old February 26th, 2013, 03:55 PM   #7
+1 for what Jeff says. Full res stills can put a strain on PP IME. I tend to resize to about 120% of the frame size, because that makes sure I don't try to pan & scan to far and too fast because that does not look nice. And it also limits the strain on system resources.
I didn't know about the thing with CMYK, but agree colour space is important. A wee bit off topic, but I used to moan about the competition secretary at our camera club, because I was convinced he'd buggered up the projector/laptop calibration, and my pictures used to look flat and under saturated. Turns out I had been submitting my pictures in Adobe RGB, when the spec clearly asks for sRGB. Once I'd got onside with that, my pictures looked the same at the camera club as they do on my computer monitor.
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old February 26th, 2013, 04:38 PM   #8
I just tried dropping an AI file in CMYK into the timeline and it appears as a preview in the project window and on the preview screen. All RGB files except RAW appear regardless of size on my version. Until your friend confirms being on the latest version she may be spinning her wheels.
Old February 27th, 2013, 08:45 AM   #9
Thanks everyone...she is going to upgrade the video card and see what happens!
