Premiere monitor much brighter than output at DVinfo.net
Adobe Creative Suite
Old August 4th, 2012, 02:10 PM   #1
I´ve been doing some tests n Premiere CS5.5 and everything looks perfect on the program screen, but when I export the final file it looks way darker and with much more contrast (I thought it could be the computer monitor but when I´ve viewed the file on my hdtv it still looked way darker and with much more contrast. I will never be able to CC correctly this way.
How can I fix this??
www.rafael-lopes.com
Rafael Lopes is offline   Reply With Quote
Old August 4th, 2012, 02:26 PM   #2
Re: Premiere monitor much brighter than output
For correct CC you need to use the build in scopes (and preferably a calibrated monitor).
Old August 4th, 2012, 02:33 PM   #3
But there has to be a way to use Composit Monitor and get the same brightness and contrast I get on my computer monitor for everything else (which matches what I see on my 2 hdtvs).
Old August 4th, 2012, 05:45 PM   #4
Does the video on the Output Tab on the Export Media screen also look darker? That would be a tip that there's an issue.
Kawika Ohumukini is offline   Reply With Quote
Old August 4th, 2012, 06:13 PM   #5
No, the output monitor on the media export looks exactly like the image on Premiere's monitor.
There has to be a way to make the monitor image darker or brighter without touching anything else.
Old August 5th, 2012, 04:00 AM   #6
If the image looks different on your tv you need to adjust the tv.
Old August 5th, 2012, 04:22 AM   #7
You TV uses REC 709 colorspace and an other gamma, than your computer monitor.
Calibrate your computer monitor to those specs and your are fine.
Or use the second output of your graphic card ,to drive a second Coputer monitor - than you can route a second program window (fullscreen) to it. Also needs 709 colibration though.
Also check this out, should help you to calibrate your output: http://blip.tv/phil-crawley/colourim...for-tv-6041222
Frank
Frank Glencairn is offline   Reply With Quote
Old August 5th, 2012, 05:14 AM   #8
I don´t think you guys got it. It ONLY looks brighter on Premiere. When I export the file and play on the COMPUTER it looks darker (like it does on any other tv or computer I´ve played this file on). sO I have find a way to make PREMIERE's in program monitor screen to look the same way the laptop monitor does, not the other way around. If I play any file on my laptop and on other computers and tvs they all look the same. The problem is premiere.
Old August 5th, 2012, 05:51 PM   #9
Would help to know what kind of graphics card you're using and if you are using any third-party calibration or monitor tools. Sounds like you have something messing with the video lookup tables that only affects Premiere, perhaps.
Old August 5th, 2012, 05:56 PM   #10
GeForce GT 540M.
I have never calibrated the laptop monitor.
This should be easy. I refuse to believe that inside Premiere there ins´t an option to increase/decrease the brightness/contrast of it's monitor.
Old August 5th, 2012, 09:42 PM   #11
Shot in the dark, then. Right click on the desktop, select nVidia control panel, go to Display >adjust desktop color settings and see if the "Other applications control color settings" is selected. This would let Premiere --- which does not, as far as I can discover, have an independent adjustment for the video playbacks --- control it's own color. (The display lighter/darker preference does not affect the video.)
Failing that, maybe try the opposite, use the nVidia settings and calibrate your monitor visually using the provided sample images, and see if that helps. Remember your original settings so you can change back. Then go further down to Video > adjust video color settings and decide if you want to use the video player settings --- which in the case of Premiere, apparently you can't change, or if so, someone please jump in here ---- or try adjusting your video with the nVidia settings, in which case all your videos should be controlled by the nVidia panel and look the same. Again, remember your settings so you can put things back if this doesn't work out.
Why the video settings would affect only Premiere I do not understand, but these checks are quick to make and easily reversable if they don't help.
PS: do you have any add-ons, like a capture card that might be loading its own video look-up table?
Old August 6th, 2012, 01:00 AM   #12
GeForce GT 540M.
Laptop monitors are notoriously bad with regards to the factory default 'calibration', which is not calibrated at all. But it is easy to do. Get a Spyder4ELITE - Datacolor Imaging Solutions - Datacolor Imaging Solutions and calibrate your monitor.
Old August 6th, 2012, 04:28 AM   #13
Guys, again, the problem is with Premiere. I can darken or brighten my laptop monitor as much as I want but the monitor on Premiere never matches the one on my laptop. BTW, I have other videos on my laptop and they look perfect on it, on other computers and other TVs.
Here is an example of the issue. On the left you can see the video that I exported and on the right you can the the video on Premiere's video monitor (which is how I´d like the video to look when exported).
http://farm9.staticflickr.com/8422/7...2a2c2252_b.jpg
Old August 6th, 2012, 04:37 AM   #14
From the VLC FAQ section:
Videos are too dark
Often this is caused by video hardware overlay problems:
If it is only one video then use the "Settings" menu, option "Extended GUI" and try to increase the Gamma value in the "Video" tab.
Check your video card settings and turn off hardware video overlay. If the videos now play with proper lighting, then deinstalling and reinstalling the video drivers might help.
Old August 6th, 2012, 04:41 AM   #15
If it was a problem with the media player it would look good on the tvs where I also tested. I´ve tried with media player classic and windows media player and it still looks dark.
