TITLES and STILL frames
Hi. I am new to Adobe CS5 and an just starting to edit my HDV video for the first time in Adobe premiere Pro CS5 . I have come across a couple of problems. have several video Tutorials and am managing quite well. However after making titles I find I can't save each title as a seperate file in order to use them again in other projects that may come along. Is this the case, that they cannot be saved outside the project. Also after making a still frame from the timeline, I find I can't save that either as a seperate item. With other editors I have always been able to do this saving. The still frame is important to me to use as a picture on the end product DVD or Blu-ray disc. Also I use the stills from the timeline to use on the case covers. Will some opne tell me if I am wasting my time trying to save the items which is not possible do with CS5, or am I doing something wrong?
Any info gratefully received. |
Re: TITLES and STILL frames
The titles are embedded with each project. The best way may be to create a new Photoshop file with the dimensions of your footage and save it as a PSD file, you will be able to edit this at any future stage.
Regarding the screen capture, you can save this as a JPG, TIFF, PNG once the capture has been made, experiment a bit further and you will find the option - sorry I haven't got CS5 installed on this system so can'give further details.
Eyes are a deaf man’s ears. Ears are a blind man’s eyes |
Just Launched Premiere CS5.5. If you click on the camera icon under the Monitor window then you are given the option to Export Frame. Give your frame a name, choose file format; DPX, GIF, JPEG, TIFF, PNG, Targa or BMP. Click the Browse button to choose a location to save the file. The image can now be added to your project.
Roy,
Just been looking at the Title feature. Once you have created a title then highlight it in the Project Panel (not on the timeline) then select Export > Title. This will save the title file as a Title Designer Title (*.prtl). To open this you must select Import and navigate to where you saved the file. A Photoshop PSD file is still a good alternative, but for simplicity the method above works.
Eyes are a deaf man’s ears. Ears are a blind man’s eyes Last edited by Vincent Oliver; June 10th, 2012 at 06:44 AM. |
#5 |
VINCENT- Thankyou very much for your excellent instructions. I have now, thanks to you, saved the items I needed as independent files. It amazes me that I have purchased two expensive visual tutorials for CS5 and neither of them mention how to save these items. Good job we have forums to get advice from. Thank again Roy
#6 |
You are welcome Roy, I know how frustrating it can be to find simple items. It's all part of the fun - sometimes!
#7 |
Vincent,
... and thanks from me too. I have often wondered about saving titles and now have the answer. Brian |
#8 |
That is one of those things that has driven me crazy for years.... Thanks from me too..
#9 |
I'm glad you have all found the Holy Grail of saving Titles in Premiere
