exporting 4 channels unmixed audio for post
I'm using CS5 and have just finished an edit using four channels of various audio (ambient, soundtrack, voice, effects) I want to send it to a post-production audio suite for a proper mix and eq. What is the best way to export and retain 4 seperate tracks??
Re: exporting 4 channels unmixed audio for post
For CS5 I believe your only option is to export stems.
Creative Impatience - The Solace of Simple Solutions. A few useful plugins for Adobe users, and my remarks on the tools and the craft in general. |
Bart,
What do you mean "stems". Are you saying one track at a time and then synch ?? |
I think the most straight-forward way is to output each track, one at a time....silence the other tracks (click the loudspeaker icon off on the unwanted tracks) , select the track you want to output and send to AME as an AIF or WAV file, then do the others in turn. I had some idea I can't test of sending a 5.1 surround project to Audition and selecting "export as individual mono wav files" from there, but I can't test this, so it's just a conjecture.
#5 |
Thanks Battle, I might follow this up as there has got to be a simple way to export all tracks simultaneuosly as seperate tracks, rather than them being mixed on export. It's for a TVC and I'm really not up on audition at all which is why I want to send them to an audio post place for sweetening and eq'ing..
#6 |
Chris, flying blind on this as I am still on CS4, but:
try making a new sequence with a 5.1 setup, copy your audio tracks to that, and then send them to Audition. Audition has an option under the Surround Encoder dialog box to export as six individual mono wave files. PPro will make empty tracks to make up the 5.1 if you only have 4 tracks. Disclaimer: I have an Audition manual but do not currently have the program, so I am working from not being able to test the idea. You don't have to know Audition in detail to do this, I think, and the help files should answer any problem that might come up. That said, it's really quick to export the audio files individually as I outlined (click off the export video option on the export window) and that I did test, and it was pretty easy. |
#7 |
Thanks Battle I'll try both those options and see how I go. Will let you know.
