What if my clip contains 2 or more scenes? at DVinfo.net
Adobe Creative Suite
Old June 5th, 2012, 01:28 AM   #1
Hi.
Let's say I have a video clip that contains 2 or more usable items, especially where those two items are relatively unrelated. For example, I have an opening narrator shot that ends with a blooper. I want to use both, but I won't put the blooper in the opening of the finished product.
Is it typical to import the clip twice, and mark separate in/out points, then use each as though they were different clips?
I'm motivated to do this, because I like using the "Video Usage" counter to make sure I don't overuse clips, and this way I will keep the correct counts.
Richard
Richard Cavell is offline   Reply With Quote
Old June 5th, 2012, 01:29 AM   #2
Re: What if my clip contains 2 or more scenes?
create subclip....
opps, right answer, wrong forum ;-(
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old June 5th, 2012, 11:29 AM   #3
You only need to import the clip once.
Then you can set various in & out points and use the clip repeatedly in your project as needed.
Bob
Robert Young is offline   Reply
