Adobe Compression at DVinfo.net
Adobe Creative Suite
Old February 14th, 2012, 11:35 AM   #1
Adobe Compression
When compressing on Adobe Premiere Pro the compressed video seems to to be about a stop darker than when it was before compressing. Why does this happen? What can be done to avoid it?
Tom Cook is offline   Reply With Quote
Old February 14th, 2012, 12:06 PM   #2
Adobe Systems
Re: Adobe Compression
What is your source format?
Kevin Monahan - Support Product Manager—DVA
After Effects - Premiere Pro - Media Encoder - Prelude - SpeedGrade - Encore
Kevin Monahan is offline   Reply With Quote
Old February 14th, 2012, 06:33 PM   #3
Source format is a nikon D7000, 1080p 24fps .mov file.
Old February 15th, 2012, 04:11 AM   #4
Did you happen to use QuiRcktime to encode? There is a reason for that name, the gamma shift that QuiRcktime introduces. You may be better off and faster with using H.264 for your encodes.
Old February 15th, 2012, 04:49 PM   #5
It's always seemed to me that Quicktime lightened, rather than darkening, the original, but maybe because the originals were done in FCP with quicktime and then looked light if played back with QT for PC....
Whatever, I have a D7000, if you want to let us know what your compression type and setting are, I'll see what I can experiment with, if you like.
Battle Vaughan is offline   Reply
