Best way to deal with drift
I have an audio recorder (Tascam Dr-40) that is drifting out of sync with my camera's and other recorders.
I have just been cutting the clip every 15 mins and re syncing. Seems like there would be a better way to do this in Premiere?. I tried adjusing the speed, but could not get a number that would make it stay in sync for the full ~1 hour. How are others dealing with this in Premiere? Thanks Ben |
Adobe Systems
Re: Best way to deal with drift
Make sure the sample settings in your sequence match the sample rate in your source footage.
Kevin Monahan - Support Product Manager—DVA After Effects - Premiere Pro - Media Encoder - Prelude - SpeedGrade - Encore |
#3 | |
Singular Software - DualEyes Note that this is a different product than their "Plural Eyes." Plural eyes lets you pick a point to have various audio and video tracks in sync but, AFAIK, it does not correct for drift. If you check out "Dual Eyes," let us know how it works. |
I do exactly the same thing. I use a Zoom R16 8 track recorder for theatre work, and this drifts by about a frame every 15 minutes, although it does vary.
On the Premiere timeline I sync up the 8 audio tracks with the camera audio at the start of the recording and check through the timeline listening for the points at which the R16 audio is starting to drfit from the camera audio, then I zoom into the timeline until I can see single frames and snip out one frame from all of the R16 tracks. Repeat until the whole timeline is in perfect sync - usually takes about 20 minutes for a two hour show. The cuts in the audio tracks are undetectable, and avoid the need to apply processes to the audio which could result in resampling and a potential loss of quality. |
