H.264 export not working from CS3 at DVinfo.net
Adobe Creative Suite
Old December 12th, 2011, 03:36 PM   #1
Hoping to get some help. I haven't had the need to export in HD intil recently as all my projects have tended to be to DVD. Finally I need my HD function so my output looks as great as it does in the edit - however it isn't working. The end result cannot be played, even if I download different players other than Windows Media Player or Classic Media Player.
I am working in PAL and 25 fps but don't see that this will be much different to NTSC settings. I am exporting using Matrox Media Encoder and the settings are:
Format: H.264
PAL
640x360
25 [fps]
progressive
Square pixels
Thanks guys.
Sara
Sara Hardie
Melbourne, Australia
Sara Hardie is offline   Reply With Quote
Old December 12th, 2011, 03:57 PM   #2
Re: H.264 export not working from CS3
How about Quicktime? Any luck with that for playback?
"For I know the plans I have for you,” declares the LORD, “plans to prosper you and not to harm you, plans to give you hope and a future." Jeremiah 29:11 [NIV]
Jon Doughtie is offline   Reply With Quote
Old December 12th, 2011, 04:10 PM   #3
No luck there either. I had downloaded the most recent quicktime but it still wasn't being recognised.
Sara Hardie
Old December 12th, 2011, 04:24 PM   #4
When I export with these settings, I get an error message "The profile could not be set, you should close the application and restart"
I also end up with 4 exported files from mymoviefile sequence - they being:
4513078 189,342 KB MPEG-4 video
4513078 2,995 KB AAC file
s2dg 192,282 KB File
mymoviefile 0 KB MPEG-4 Movie
Does this ring any bells for anyone?
Sara
Sara Hardie
Old December 13th, 2011, 03:53 AM   #5
Hi
So long ago I used CS3 - I think I had some problems too exporting in HD H264. I got CS4 because I needed to export into HD
Bo Skelmose is offline   Reply With Quote
Old December 13th, 2011, 05:58 AM   #6
640x360 does not sound like HD.
Old December 13th, 2011, 08:59 AM   #7
I agree. In fact, in PAL countries like Australia, resolutions as high as 720x576 are only SD. What happens there is that the H.264 encoder in CS3 is either completely incapable of upconverting SD to HD (meaning that the source material would have to be already in HD - 1280x720, 1440x1080 or 1920x1080 - in order to encode in H.264 HD with CS3) or that the output settings are set too low for the HD encoder to work at all.
Randall Leong is offline   Reply With Quote
Old December 13th, 2011, 10:13 AM   #8
Sara, not at my works computer but from memory, go into the Adobe Media encoder and choose h.264, then scroll down to the frame size and choose 1920 x 1080 or whatever your project is set at. Set the compression and hit export. I'll have a look when I get back to work and if it's any different I'll re post.
Just re-read your post, what's your project settings as 640 x 360 = half 1280 x 720?
Have you thought about Mpeg 2, and tried it with various bit rate settings?
Peter
Peter D. Parker is offline   Reply
