CS3 Master + Windows 7 Pro 64 Bit Issues? at DVinfo.net
Adobe Creative Suite
Old October 18th, 2011, 04:27 PM   #1
Anyone have any issues with CS3 and Windows 7Pro 64 Bit?.
I'm upgrading from a computer with XPPro to a new one hopefully with Windows 7 64 bit + CS3 Master + Neo/Neoscene.
I have read some find CS3 runs fine,others need to run in XP Mode and for others there are problems.
Matthew Cairns is offline   Reply With Quote
Old October 19th, 2011, 01:05 PM   #2
Adobe Systems
Re: CS3 Master + Windows 7 Pro 64 Bit Issues?
Premiere Pro CS3 runs on a 32 bit OS. I can't recommend running it on a 64 bit OS, even if it will launch. I advise you to stay on XP until you upgrade to Premiere Pro CS5 or later.
Kevin Monahan - Support Product Manager—DVA
After Effects - Premiere Pro - Media Encoder - Prelude - SpeedGrade - Encore
Kevin Monahan is offline   Reply With Quote
Old October 19th, 2011, 06:58 PM   #3
Thanks Kevin,
Are you able to indicate how effective the combination of CS3 would be in XP Mode in Win 7?
Cheers
Old October 21st, 2011, 04:24 AM   #4
Matthew, I use 64 bit Vista ultimate and CS3 Production Premium suite, and never had a single problem.
Don't have any personal experience with Windows 7, but I don't see why it should cause you any trouble since CS3 performs well on 64 bit Vista.
Trond Saetre is offline   Reply
