Premiere crashes if monitor is turned off. at DVinfo.net
Adobe Creative Suite
Old October 5th, 2011, 10:54 AM   #1
Here's an odd one. Am running CS5.5 on a Mac Pro tower with a Quadro. It seems if you turn the monitor off or disconnect it in any way, Premere will crash.
I've reported this to Adobe. Quite annoying as I often switch my monitor to my PC when rendering so I can do admin. Or if the computer is doing a long task I may turn the monitor off to save power.
I'm guessing it has something to do with CUDA and the GPU being used to do the processing. Perhaps the card goes to sleep or something if it detects it isn't plugged into anything?
Anyone else noticed this?
Marcus Durham
Media2u, Corporate Video Production For Your Business - http://www.media2u.co.uk
Marcus Durham is offline   Reply With Quote
Old October 5th, 2011, 05:40 PM   #2
Re: Premiere crashes if monitor is turned off.
I learned the hard way during an After Effects render. Set it up for an overnight render. Shut the monitors off and went to bed. Next morning turned the monitors on and AE had crashed after just a few minutes so it was sitting idle the whole night!
Lesson learned!
Old October 6th, 2011, 01:14 PM   #3
Not very good is it? I suspect a lot of us leave our edit suites running overnight from time to time when running long tasks. The old version of Premiere I used to use was fine with this and so is Final Cut. Not quite sure why modern Adobe software is different.
Marcus Durham
