Picture size limit when importing a still? at DVinfo.net
Adobe Creative Suite
Old August 16th, 2011, 07:42 PM   #1
Hi All,
In CS 3.2 I'm trying to find out how much I need to crop some pictures taken with a Canon D-90 (12+MP).
What are the dimensions in pixels/cut-off for importing stills from that source?
Failed with Adobe help.
Bruce Pelley is offline   Reply With Quote
Old August 16th, 2011, 09:44 PM   #2
Re: Picture size limit when importing a still?
Canon doesn't make a D-90. Are you referring to a Nikon D90?
Old August 17th, 2011, 12:21 AM   #3
CS3 hates stills, and especially hates them if they're bigger than necessary. Anything bigger than 1920 x 1080 is bigger than necessary unless you are zooming or panning or otherwise doing motion with your stills. And a word to the wise... png is the format Premiere likes best.
I learned all of this the hard way.
Old August 17th, 2011, 01:18 PM   #4
I believe with CS3, 4000x4000 is the largest acceptable size to import a still. If you want to pan/zoom around in the still to add motion, you can benefit from the larger size, but if you just need a static shot, then definitely scale down to video size or you will bog down the works with the oversized stills
Jeff Pulera
Safe Harbor Computers
Jeff Pulera
Old August 17th, 2011, 02:32 PM   #5
Adobe Premiere Pro CS3 * Import files
Old August 18th, 2011, 10:35 AM   #6
Whoops! Sorry, yes I meant to say Nikon not Canon.
Thanks for all of your involvement.
I can now import pictures however, after editing .... when exporting them (added color matte + title) when viewed the quality had suffered greatly. Very unfavorable compared to the original.
Don't have full-blown Photoshop so I was trying to make do.
What can be done to dramatically improve the output?
What export settings/format et. al. are best for a edited still?
