Modifying Seperate Channels in Stereo Track Premiere CS5 at DVinfo.net
Adobe Creative Suite
Old May 31st, 2011, 05:01 PM   #1
Hi guys. How do I turn down the audio volume of one channel in a stereo track without modifying the other channel. I had a shotgun mic in my left channel and a lavalier mic in right. The lav mic is way too loud and distorted and I would like to turn it down in Post in Premiere CS5. If it can't be done I also have soundbooth cs5. Thanks
Victor Boyko is offline   Reply With Quote
Old June 2nd, 2011, 06:48 AM   #2
re: Modifying Seperate Channels in Stereo Track Premiere CS5
you can use the two channels as two mono channels instead of one stereo. In the project panel right click on the clip and choose modify - audio tracks.
Zoran Vincic is offline   Reply With Quote
Old June 2nd, 2011, 02:35 PM   #3
You can use channel mixer to modify separate gains for left or right.
But you can also use Fill Left (or Fill Right) to fill one channel with the other one: this way the bad audio is gone and the good track is on both left and right.
Checking out and trying the different audio effects (from the stereofolder) will help you find a lot of anwsers ;-)
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply
