Premiere Pro exports coming out blue at DVinfo.net
Adobe Creative Suite
Old May 6th, 2011, 04:14 PM   #1
My project exports out mpeg-dvd without a hitch but when I try exporting a master / archive large format like quicktime animation, parts of the final video have a blue tint as if only the blue channel is showing. Is this an alpha related issue or a codec problem? I'm befuddled!
Brannon Bates is offline   Reply With Quote
Old May 6th, 2011, 04:39 PM   #2
Re: Premiere Pro exports coming out blue
pic attached above
Old May 6th, 2011, 08:27 PM   #3
Does the blue tint show up in the AME preview window, or is it a function of pure playback??
Old May 6th, 2011, 08:38 PM   #4
I can see it in the adobe media encoder preview window too. I checked the actual video after export to make sure it wasnt a preview window mishap but the blue is in the final video as well. It doesn't happen with say mpeg exports but I didn't know if that makes it a definite quicktime codec issue or if it's an alpha issue if quicktime displays alpha and mpeg doesn't?
Old May 7th, 2011, 12:10 PM   #5
How about PC Uncompressed vs Quicktime Uncompressed? This might be a Quicktime issue, but first check native codecs.
Creative Impatience - The Solace of Simple Solutions. A few useful plugins for Adobe users, and my remarks on the tools and the craft in general.
Bart Walczak is offline   Reply With Quote
Old May 7th, 2011, 02:56 PM   #6
It's definitely quicktime related, everything else exports normal. I just wanted a master / archive copy for backup so I can delete the project files eating up my hard drive. I'm exporting out a lossless lagarith avi as a backup, anybody know if that is ok? The original footage is 1080 24p, and I want a master copy that can go to betasp//digibeta and even 35mm if needed.
Old May 8th, 2011, 02:31 AM   #7
If you want to retain quality, I'd go for 10-bit uncompressed avi. You can also try to download codecs from Blackmagic Design and export as 10-bit Uncompressed 4:2:2. Or you can invest in Cineform (it's only $129 for the basic version) and export it there - less space, excellent quality.
Old May 8th, 2011, 03:09 AM   #8
great suggestions, I think I'll try out that cineform. For some reason my quicktime is shot, and I even had an avi export turn out blue. I tried lagarith and it dropped frames throughout unfortunately because the file size was nice, and there was no blue.
Old May 9th, 2011, 10:36 PM   #9
try exporting to a 8 bit codec and see if the problem goes away
and if you have hardware CUDA on, try software CUDA instead ( project settings )
this could in face be a problem with a 10bit codec not being seen correctly by the exporter
Steve Oakley DP • Audio Mixer • Editor • Colorist
http://stevenoakley.com
Steve Oakley is offline   Reply With Quote
Old May 10th, 2011, 02:20 AM   #10
both 8 and 10 bit gave me blue. So did avi eventually. I never solved this problem. I ended up exporting out a huge .tif sequence (about 1000 gigs) for my archive copy. If anyone else has a solution to this please let me know.
Old May 10th, 2011, 03:49 PM   #11
Adobe Systems
Do you have an AJA Kona card in your system? If so, update to the latest drivers. That should solve the issue you're having.
Kevin Monahan - Support Product Manager—DVA
After Effects - Premiere Pro - Media Encoder - Prelude - SpeedGrade - Encore
Kevin Monahan is offline   Reply With Quote
Old May 10th, 2011, 05:27 PM   #12
nope nvidia and i updated those drivers with no luck resolving mr blue man
Old May 10th, 2011, 09:42 PM   #13
Maybe you have this covered:
1. Uninstall QT and reinstall latest version.
2. Open another project with a sample footage and export to QT - is the problem with this particular project or any and every project (different source files/frame rates, etc)?
3. Export a black and white shot - does it still show a blue cast?
Hope this helps.
Sareesh Sudhakaran is offline   Reply
